Old 10th March 2011, 12:44 AM   #1
Default Designing x-over when amp output 2.3 Ohm impedance
If I am designing a crossover from scratch, and the output impedance of my amplifier is 2.3 Ohms, where do I take into account this figure.
Do I add 2.3 ohms to all of the drivers at the outset?.
Do I subtract 2.3 ohms from all of the drivers?.
Do I not worry about it?.
Old 10th March 2011, 01:27 AM   #2
If you are tying these speakers to this specific amplifier, then you could model with 2.3ohm as the first series element in the crossover (amplifier side) with tweeter and woofer circuits teeing of after this resistor. (This is assuming the output impedance is flat across the band.)
To make a high-impedance friendly speaker that isn't tied to a specific source impedance, some designers add parallel RLC notches and zobels to flatten the impedance seen by the amplifier. Most seem ignore trying to flatten the woofer resonance since it would take an expensive inductor.
Old 10th March 2011, 02:32 AM   #3
Yes, the impedance is flat across the band.
How do I compensate for a resistor of 2.3 ohms as the first element?. Where does this value have an effect?.
2300 ohm vs 5000 ohm output trans question speakerfritz Tubes / Valves 4 2nd October 2010 10:17 PM
How to connect 62 ohm headphone to 8 ohm output Sunsun22 Headphone Systems 15 16th June 2007 01:29 PM
Designing amp to withstand shorted output mr.duck Solid State 27 27th December 2006 04:02 AM
Help in designing of current output amp Edo Solid State 24 14th October 2002 09:26 AM
4 Ohm or 8 Ohm speakers impedance for Aleph 5? Piter Pass Labs 2 1st November 2001 07:15 PM
Page generated in 0.08278 seconds (59.48% PHP - 40.52% MySQL) with 10 queries
