Do you need a crossover/filter for a sub?
Old 9th March 2011, 03:58 AM   #1
TheLaw117 is offline TheLaw117  United States
Default Do you need a crossover/filter for a sub?
You might know I'm working on an LM3886 Stereo amp. I'm a bit antsy you see...
While I'm in the amplifier/speaker building mode. Does anyone actually use a filter for a subwoofer? Is it worth it I mean?
EVENTUALLY, I'd like to get one of those nice 8" HiVi M8a's. Eventually...that is.
Also, is there a special type of amp required? Are 2x bridged LM3886s not good?
Thanks a bunch. Just out of curiosity.
Old 9th March 2011, 04:12 AM   #2
PeteMcK is offline PeteMcK
yes, you need one; the easiest way: TLS.org | Passive Line-Level Crossover
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 9th March 2011, 04:14 AM   #3
I mean only a subwoofer. Just a subwoofer in a box...no other speaker.
Still?
Old 9th March 2011, 04:21 AM   #4
N Brock is offline N Brock  United States
N Brock's Avatar
Yes, still. if not the sub will sound poor.
You could use a PLLXO, a passive crossover (more expensive), or an active crossover 9even more $$)
If in doubt you can try it without a crossover, shouldn't hurt anything, but most subs are designed to only play on the lower end.
N-Brock
Old 9th March 2011, 08:30 AM   #5
AllenB is offline AllenB  Australia
Do you want your sub/s to be reproducing midrange? Apart from hearing it, if it/they are not close to your mains then you may end up with cancellations (comb filtering).
Unless you build bandpass subs which have inherent physical low pass filtering.
Old 9th March 2011, 12:39 PM   #6
audiobomber is offline audiobomber  Canada
audiobomber's Avatar
You may be able to use a sub without a filter if it's strictly used for a Home Theater ".1" channel, with all the other speakers set for full range operation. For any other setup, no way, a sub without a filter sounds horrid.
Dan
Old 9th March 2011, 10:26 PM   #7
If I assume by your reply that you are keen to get on with it, a simple inductor with the speaker lead will get you started, and maybe a well chosen electrolytic capacitor across the speaker terminals to go with it. No big deal until you want to start getting exact.
Old 10th March 2011, 01:18 AM   #8
Thanks. I won't be building the sub for a while, but I was just curious...
And would I need to use a different type of amp? Or...?
Do you need a crossover/filter for a sub?Hide this!Advertise here!
Passive crossover/filter question dooper Multi-Way 2 26th January 2010 04:00 AM
high pass filter (crossover) derekyu Multi-Way 8 30th March 2007 06:32 PM
Crossover filter point spread mcdoug88 Multi-Way 3 27th September 2006 08:07 AM
Crossover or filter Optical Chip Amps 3 16th December 2003 03:52 AM
Opamps for active crossover/filter harvardian Solid State 10 3rd January 2002 03:01 AM
Copyright ©1999-2017 diyAudio
