Old 9th March 2011, 12:36 AM   #1
Default Peerless 811435 tweeter, Vifa TG9FSD10-08,
Peerless 811435 tweeter, Vifa TG9FSD10-08 Mid, Peerless 830491 Woofer
http://www.d-s-t.com.au/data/Peerless/811435.pdf
http://www.vifa-audio.com/products/d...9FSD-10-08.pdf
http://www.d-s-t.com.au/data/Peerless/830491.pdf
where would you cross these over in a 3 way setup?
or wouldn't you?
I'm a bit worried about the lack of efficiency of the vifa driver, and after purchasing realised I should have bought the 4 ohm version.
perhaps there's another mid someone could suggest to go with this woofer, and tweeter?
they are to be used in a car audio environment and 3.5inch is the limit of the midrange.
thanks!
Old 9th March 2011, 09:17 PM   #2
re:'I'm a bit worried about the lack of efficiency of the vifa driver' - with such a discrepancy in efficiency, you'd need a separate amp for the subs with active crossover to achieve a balance...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky
Old 10th March 2011, 07:12 AM   #3
Inductor's Avatar
I doubt.
The problem is not so much of passive vs. active but of the modulation of the output curves and crossover points. I would make a xover for the mid with an opposite shape of that of the graph to compensate the deep at 1KHz. The tweeter requires a relatively high xover point >3KHz because high Fs. This is the reasoning you can not achieve with "active" thinking. (Sorry I'm thinking HiFi, not car audio.) http://www.focalaustralia.com.au/
Old 10th March 2011, 08:32 AM   #4
The vifa is a full range (hence low sensitivity) driver best used elsewhere.
A small midrange will have higher sensitivity due to a much shorter coil.
(More excursion = less efficient use of the magnet field available.)
The vifa would ~ work in a hifi speaker with the others, but not for in car.
In car perhaps a sealed back midrange (need to c/o high) is your best bet,
but I've never seen any outside of the beer budget range, lots of those.
rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann
When your only tool is a hammer, every problem looks like a nail - Abraham Maslow
Old 11th March 2011, 09:09 PM   #5
I remembered after posting this that I'd planned to run a full active setup anyway
still need a more suitable midrange though me thinks.
WTB Vifa C13WG-08-08 bernat Swap Meet 2 26th March 2011 08:34 PM
4x new Vifa (Peerless) P13WH-00-08 h_a Swap Meet 1 30th November 2010 09:24 AM
What's the difference Vifa d75mx 41-08 and Vifa d75mx 31-08 kabaraka Multi-Way 2 21st May 2009 01:53 PM
FS: Vifa XT18WH09-08 & XT18WO09-08 Woofers sphinx Swap Meet 0 9th May 2008 06:42 PM
inexpensive tweeter to match vifa TC18WG-15-08 SQ Kid Multi-Way 15 7th August 2004 05:21 AM
Page generated in 0.08677 seconds (69.32% PHP - 30.68% MySQL) with 10 queries
