Old 8th March 2011, 11:41 AM   #1
Default baffle step diffraction losses for my system.
I have a driver for which i want to calculate baffle diffraction losses. The problem is its magnet is as wide as its diaphragm size. Also after I mount it (Flush mount) its gape is covered with the front panel.So probably using enclosure dimensions might not help. is it?
Pl. tell me how do I calculate baffle step diffraction losses for my system.
I am attaching the pics.
There is always a first time....
Old 8th March 2011, 04:51 PM   #2
i absolute have no clue how to calculate it in your situation, but prehaps you can anytime mesure it with a mic , i would guess.
placement of the speakers have a big impact on baffle stepp.
so it is -even if you do calculate it- a good practise to mesure the speakers at the place you gona use them, and redo your calculation. (or just mesure..)
Old 8th March 2011, 06:08 PM   #3
speaker dave's Avatar
Baffle diffraction is primarily determined by baffle dimensions and location of the driver. Size of the magnet isn't a factor. Here is a handy simulator worth playing with:
Home of the Edge
With the magnet that tight to the back of the baffle you might want to put a 45 degree champfer on the back side of the woofer opening.
David S.
Old 8th March 2011, 06:58 PM   #4
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Default Here, try this.
Try this online calculator.
Difraction Loss / Baffle Step Compensation (BSC) Circuit Calculator
Old 8th March 2011, 07:02 PM   #5
AEIOU's Avatar
You need to chamfer or bevel the inside of the mounting hole so the woofer can breathe.
Diffraction has nothing to do with magnet size, the magnet is inside the enclosure or on the back side of the baffle. Diffraction, loss and diffraction stpe is what happens on the front side of the baffle/enclosure.
Old 9th March 2011, 06:50 PM   #6
Thank you all for the time here.
I got a good news from mt carpenter, he is not able to do that chamfer job. But yes I guess that is the only alternative I have.
Aeiou and dave thanks for the tools. I have been using Edge for diff. losses.
I was worried about magnet because I was worried if magnet is the first obstacle,so was worried.
Old 9th March 2011, 06:59 PM   #7
AEIOU's Avatar
You can do the chamfer yourself. Use a wood rasp! Pull out the woofer and stick your hand in the hole, it doesn't have to look pretty because it's on the inside.
Old 9th March 2011, 07:00 PM   #8
any tool available where I can subtract my measured frd file of speakers with the filter (diffraction correction) frd.
so I can get to see result.
Old 9th March 2011, 07:07 PM   #9
AEIOU's Avatar
Maybe this?
Loudspeaker Design Software
Or this?
Seas + Celestion FRD Baffle diffraction and step analysis gfiandy Multi-Way 1 20th October 2010 11:18 PM
Compare IGBT-losses and MOSFET-losses kall Power Supplies 12 13th September 2010 05:01 PM
Baffle diffraction step - is this right? buzz1939 Multi-Way 6 6th May 2007 05:55 PM
baffle step on just midrange or whole system mazurek Multi-Way 5 17th April 2006 01:53 PM
Edge diffraction: large, rounded baffle, or narrow square baffle fortyquid Multi-Way 12 12th January 2004 03:43 AM
Page generated in 0.11766 seconds (76.47% PHP - 23.53% MySQL) with 11 queries
