Hi for last 10 yrs I was mostly with Fr fitted in BLH.
Onward I want to move into BR cab for bass, Horn for 500/600hz and above. For bass I like cornwall/cornscala type cabinet of similar size, and install 850/950pb or FP HF200 in a 250/300hz Tractrix horn on top (not in the bass box) and 2 way simple passive crossover. My amp is 300B Se with 5 watt output power. Listening level is low to moderate and room size is 16'x27' where half of the room is for dinning. This Ahuja Sound Solutions or this one Ahuja Sound Solutions is available locally, question is Can I fit any of the above into cornwall or cornscala cab? if not What mod I need to perform to the cornwall or cornscala cab OR You suggest any other cabinet BR/slot loaded (like cornwall), T-TQWT, TL which will play 35hz-600hz well. Appreciate your input/suggestion. Regards |
| Henkjan's easter project 2010 - compact horn/BR with Alpair6 | Henkjan | Full Range | 46 | 2nd August 2011 02:15 PM |
| Best slam and punch in the bass for hifi (not PA): TH with 15 OR 2x15 BR OR 1x18 BR? | pk | Subwoofers | 19 | 12th March 2011 06:24 AM |
| Active controlled BR-system | b_force | Multi-Way | 0 | 18th June 2010 09:43 AM |
| Three way horn system | pelanj | Multi-Way | 28 | 11th August 2008 01:16 PM |
| FE126E back horn, 127E double BR : who really built it ? | ow31 | Full Range | 29 | 14th June 2006 02:06 PM |
| Page generated in 0.05266 seconds (76.28% PHP - 23.72% MySQL) with 10 queries |
