I am planning to build a 211 single ended tube amp for my B&W N802. This is only 15-18W per channel. Considering N802 has only 89dB, is this sufficient to drive it?
What about 845 single ended tube amp with 24W output? Although 845 has higher power, 211 is much better in details. |
#2 |
Does not sound like a great idea at all and not just because of the sensitivity. Guess you already knew it. A push pull 211 would do fine though.
#3 |
I like SE of its details. Perhaps I should ask in the tube amp section for their opinions too.
#4 |
Banned
B&Ws are generally quite power hungry and benefit from higher power amps.
| ~17-18w sweep tube with large plate cap | rsumperl | Tubes / Valves | 8 | 21st February 2011 11:41 PM |
| FA: Eico HF-85 Tube Preamp & HFT-90 Tube Tuner | joe-electro | Swap Meet | 0 | 31st May 2009 04:14 PM |
| The Spassvogel MT's (Scanspeak 6600 & 18W/8531) | JonW | Multi-Way | 5 | 14th October 2008 01:57 PM |
| WTB: Scan Speak 18W/8535, 18W/8545, or 18W/8545K | omarmipi | Swap Meet | 3 | 26th April 2008 06:48 PM |
| SMPS & tube pre-amp development board. | ianl | Tubes / Valves | 2 | 10th April 2006 06:05 PM |
| Page generated in 0.07218 seconds (72.76% PHP - 27.24% MySQL) with 10 queries |
