need info on 2 way sys....
Old 7th March 2011, 01:39 AM   #1
JoeDJ is offline JoeDJ  United States
JoeDJ's Avatar
Default need info on 2 way sys....
First off...
Hellow!
I just found this place.
I got the speaker building bug and I must admit that I have much to learn about it.
This is what I want to do.....
I want to put together basically a 2-way sys for my TV.
It will consist of a 8 ohm 3" full range driver and a 1" 6 ohm tweeter with a 3k crossover.
Also, I want to add a 8 ohm L-pad to adjust the tweeter level.
This wiil be driven by an amp that can handel a 4-8 ohm load.
Is all this OK? Am I right in assuming that the cross over will maintain basically a 8 ohm load?
Also, is the fact that the tweeter is 6 ohms of any significance?
BTW, the 3' driver will be a "Tang Band W3-881SJ". Is 3K a good cross over point for it.
Also, the sys will be fed through the high pass filter of a powered sub.
Although, I may set it up so I can bypass the sub if I want to.
Any and all input is gretly aprceiated.
Thanks.
Old 7th March 2011, 06:33 AM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
If you got the 'fever' , don't matter . Take all the speakers you want and
start making boxes . I would say 3 KHz may be good if the 3" is used as a midrange ,so you may cut lower.
Old 7th March 2011, 06:44 AM   #3
GoranB is offline GoranB  Poland
GoranB's Avatar
For cut-off frequency of 3KHz you should install the driver in proper distance between them. I wish i could help about this but i dont know how to count the relations between distance of drivers and cut off frequency. Im sure someone on this forum will help You about this.
Old 7th March 2011, 12:47 PM   #4
JoeDJ's Avatar
Thanks for the replys.
One thing I was not sure about is the electrical intergity all what I want to do.
Is the fact that the tweeter is 6 ohms a problem?
Will the crossover maintain basically a 8 ohm load?
Any other potential problems?
As far as acoustical coupling or interferance betwen the two are concerned, I do plan on mounting the tweeter in a seperate enclosure so, it can more or less be moved to a optimum location.
Thanks for pointing that out though as the seperate enclosures were originally going to be just to make it easier to install in a particular area .
However, it wiil also allow some movement between the mid driver and the tweeter.
Also, i picked 3k as the crossover point because some were saying higher and some lower. I just compromised with 3k.
However, I just want to take advantage of the expertise/opinions here.
Old 7th March 2011, 09:03 PM   #5
PeteMcK is offline PeteMcK
re:'Is the fact that the tweeter is 6 ohms a problem?' - no, as long as the crossover is properly designed - i.e. you're using the actual value of impedance at the crossover freq in your calculations....
Re: crossover freq - looking at the FR plot for the Tangband, I'd crossover at 2 KHz because the driver has a jump in response above that. However, this depends on your tweeter - what is it?
(an alternative - the Tangband resonds well up to 10KHz, if it sounds good, you could just add a supertweeter from there up)
Impedance varies with frequency, use impedance plots of your drivers and make crossover calculations using the actual impedance of the driver at the crossover frequency
Old 7th March 2011, 09:50 PM   #6
JoeDJ's Avatar
OK....
I was thinking about using a "HiVi SD1.1-A" dome tweeter.
To be honest, I was basically going to mount the tweeters in the end of a small piece of PVC pipe (posibly in an end cap) so it can be moved and pointed as needed. It's a bit of a strange arangement I have to deal will in the TV room and it's hard to explain.
As for the crossover, I was going to use a Daytion Audio unit.
EDIT: After looking more closely at the specs, (freq response 2000-20000hz) it seems to me to that a higher croossover point would be prudent with this tweeter... Am I right?
I just want a relatively flat respose (to my aging ears) at low to mid volumes.
Anyway I was going to try the Tang Bands alone first to see how it sounds and take it from there. I was thinking tweeters because there is not too much hi freq reflections in the roiom...... and my old ears.
Thanks for your input.
Old 7th March 2011, 10:15 PM   #8
JoeDJ's Avatar
Thanks, that will keep me busy for a while.
Old 7th March 2011, 10:15 PM   #9
gvimhoof is offline gvimhoof  United States
Default Lots of options
Greetings and welcome to diy!
3in full range designs are plentiful. The needles, the TABAQ, the Del Sol's are just a few that pop into my mind just from this forum. The beauty of these designs is that they get you into the hobby with out killing your wallet. It's amazing what you can get out of a 3in driver with the right design.
But beware... Once you crawl down the diy rabbit hole, it's very difficult to get back out. Before you know what's happening, you're building speakers to experiment, or try a new type of design or driver, and before you know it you're building more and more speakers!
But it's cool. You're just starting out. No worries. I'm sure you'll be able to stop after just one pair.
Old 7th March 2011, 10:44 PM   #10
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I wish I had known that when I was younger. This addiction leaves hardly any money for the important things like beer, chicks and smokes.
Ya right.
planet10 needs your help:
Let's help Ruth and Dave
need info on 2 way sys....Hide this!Advertise here!
help with 3 way sys choosing tulip42 Multi-Way 11 13th March 2011 12:37 PM
EGO-SYS Waveterminal U2A rubicon Swap Meet 0 21st December 2010 05:31 PM
Here is my FR/WR125 sys...looking for tweaks now binarywhisper Full Range 14 11th January 2009 08:42 PM
Copyright ©1999-2017 diyAudio
