Just wanting some advise about the best way to make a waveguide for a rectangle tweeter, the B&G Neo3 for example.
Is it best to maintain a rectangle waveguide shape, or is it better to have a rectangle throat smoothly transitioning to a circular shape for the mouth? |
#2 | |
For more output use (4) of them in a line array (series-parallel connected). For pattern control use an acoustic lens (slant plate) in front of them. ._ . _. |_\/_| . . . . /////// _==_ . . . . _==_ Regards, WHG Last edited by whgeiger; 10th March 2011 at 12:20 AM. |
#3 |
u could try as phil jones did with his AAD7001i
Nearfield Studio Monitor 7000i ? The Finest Two-Way Monitor Ever Built | Phil Jones Pure Sound http://www.philjonespuresound.com/about/reviews/422.pdf he's one of the best speakers engineer out there cheers henry |
#4 |
Regards, Aaron |
#5 |
Hey Simon,
The Fountek neocd3.5 with wave guide seems to favour a rectangular flare. Much easier to construct for sure so maybe it was a production decision. The measurements certainly look good in terms of power response. Also similar in design to the Phil Jones 2-way monitor linked a couple of posts above. https://www.madisound.com/store/prod...oducts_id=8818 Last edited by ShinOBIWAN; 10th March 2011 at 02:32 PM. |
#7 |
lets try this one, but its basically the pic of the speaker, no more details on the horn
http://www.philjonespuresound.com/products/38/main.png cheers henry |
#8 | |
Hi, As some make efforts to go from a circular driver to a rectangular horn, one would assume in this case its pragmatic to stick with rectangular. rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
| choice of drivers - 15" + compression driver + waveguide | audiothings | Multi-Way | 15 | 4th January 2011 10:32 AM |
| rectangle shaped tweeters | skooter | Car Audio | 2 | 15th December 2007 03:47 AM |
| Round vs. rectangle ports... | RockysDad | Full Range | 3 | 24th November 2005 05:27 PM |
| PORTS!!!! rectangle square, how long? angles, corners, stuffing?? everything else | SkinnyBoy | Multi-Way | 34 | 13th August 2003 02:09 AM |
| Page generated in 0.10159 seconds (76.54% PHP - 23.46% MySQL) with 10 queries |
