Old 5th August 2003, 03:35 AM   #21
Send a message via ICQ to ArthurSoares
Originally posted by kelticwizard
Anytime, Art.
By the way, Eminence has a distributor in Brazil, so you might be able to pick up the Lab 12 in your own country.
This page is the Brazil distributor. You can Email him to see if he has any dealers near you, (distributor is the man who supplies the dealers).
http://editweb.iglou.com/eminence/em...y/sabrazil.htm
Thank u by the way, but that won't be usefull for me right now. I've already decided that I'm going to get the driver in the US.. But I'll tell some folks that want to buy it!.
Old 5th August 2003, 04:02 AM   #22
Default confused now!
Well, I was reading the Adire website and I've just got messed up!.. I've just saw this driver named Tumult, it's an improoved version of the Brahma for HT.. What u guys think about it?
Another questions, What programs u use for making boxes? WinISD?
Thanks once again!
Old 5th August 2003, 04:48 PM   #23
Eul is offline Eul  Netherlands
@ kelticwizard: Thanks for the info! It is always fun simulating two different drivers to find out witch will be best and I’m goin to do that for sure! I always believe the could be some better, even when it is not so famous as the other item. As a matter of fact… I love it when the underdog bites the big one and it is much more original to use something like this than a already proofed concept. I’m curious…
@ArthurSoares: If u want to use the Tumult you need so much power to get the max out of it, the amplifier would be even expensive as the subwoofer. So if you don’t have a problem to double your budged… I haven’t simulated yet so I cant say what it can do…
I use LspCAD std.
Old 5th August 2003, 05:21 PM   #24
I use LspCAD std.
Thank you!. About the Tumult, that was the answer I got to testing the drivers in WinISD, I think for a flat answer BRAHMA is a better choice, maybe the box with a peak is better with the tumult.
Old 5th August 2003, 05:47 PM   #25
This design should satisfy monster bass lovers.
http://www.acoustic-visions.com/everest.htm
..... 2 Tumults and four 18" passive radiators each capable of 3" peak to peak excursion .......
Old 5th August 2003, 06:10 PM   #26
edit: There is a Yellow line that was supposed to be a SHIVA 2
WOW This must be the Earthquake itself. Can u say "sound pressure"? Beautiful .. Beautiful! but unfortunatelly too expensive for me
I Made out some plots with the drivers from Adire....
They are:
Adire Tumult 15" in Orange ------
Adire Tempest 15" in Yellow ------
Adire BRAHMA 15" in Purple/Pink ------
The Enclosures:
Tumult15:
Ported-
170Liters / 6ft^3
Fb: 19,3Hz
Tempest15:
Ported-
133Liters / 4,6 Ft^3
Fb: 17,44Hz
Brahma15:
Ported-
144Liters / 5 Ft^3 aprox.
Fb: 22,05 Hz
Power Supplied in Plot:
Tumult: 1600watts
Tempest: 300watts
Brahma15: 1200watts
here are the plots:
Overall SPL
I Got based in this to set the power.
Delay
IMHO I guess that the Brahma is still the most recommended sub to my needs.
Old 5th August 2003, 06:29 PM   #27
Another question.. Where can I get plots of TL frequencies response?
Old 5th August 2003, 10:11 PM   #28
Well, I simulated the Brahma now too and is seems it wouldn’t be a bad choice.
The results of your simulation and mine are a bit different (mine are better ), I can not say who’s software gets the best to the reality.
When I put it in a 80L box, 50% filled with damping and a typical box loss ( Ql ) of 7 it can be a good HT sub. Tuned at 25Hz with 2 pipes of 8cm and 45cm long it will have a -3dB point of 23,8Hz, you can put 300W RMS! on it before it will exceed it’s X-max but at 300W the -3dB point will be 36Hz because of the non linearity of the ports , but still not bad… the group delay will be 30ms at 20Hz but that will be 23ms already when you put 100W on it. The air speed @300W @ 20Hz will be 13m/s, nothing to wory about too much. Not bad at all… Making the box bigger wil not give you better.
Now It’s bet time [edit] In Holland (00.13) [edit]
Old 5th August 2003, 10:57 PM   #29
What software u used and how could u reach Xmax with only 300watts?
Old 5th August 2003, 11:29 PM   #30
Already modeled the Lab 12 and the Shiva Mark III. Here is the result, (go from post # 16 on):
http://www.diyaudio.com/forums/showt...628#post110628
Hard to tell apart!! The 12 inch Peerless looks bad, but actually it is designed for a smaller enclosure.
All three were in identical 60 L boxes tuned to 25 Hz. You can put the Shiva and Lab 12 in much bigger boxes, tuned lower, as well.
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Passive radiator Chris8sirhC Subwoofers 4 5th August 2008 05:49 PM
Passive radiator jamikl Subwoofers 1 3rd June 2006 09:23 AM
Passive Radiator Fazorcat Subwoofers 42 10th May 2006 07:05 PM
passive radiator ??? Ahmad_tbp Multi-Way 20 29th March 2005 07:44 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
