Old 4th March 2011, 10:41 PM   #1
Audist is offline Audist  United States
Default Speakers for rock music?
I looking to build the "ultimate" loudspeakers (for my taste).
I listen to rock music, metal, orchestra, blues, etc..
I am looking for Speaker reasonable size room of 300 square feet.
I'm looking to hear and feel the bass drum kick.
I think use with VOLT RV3143 12" woofer or Accuton 9” woofer or Audiotechnology 23I52 or 10A77 or dual 18H52 woofers.
What you think is a best for Kick bass drum like a real?
I use with RAAL ribbon tweeter and a midrange will to be Audiotechnology or accuton.
Thank you very much.
(Thanks for all guy that help me on my previous post, The Morel 6" carbon is failed from my project)
Old 6th March 2011, 05:41 PM   #2
Altec Best's Avatar
I'm kinda partial to the Altec 416 In a room that size a 15" woofer would be nice IMO but then again I like dual 15" woofers per cabinet
But as always preferences rule the roost !
~ Have A Happy And Safe Holidays Everyone ~
Old 6th March 2011, 05:59 PM   #3
Twin 15" would be brilliant, definitly go for sealed enclosures, you don't want any silly ports to muddy up those bass transients.
Old 6th March 2011, 06:16 PM   #4
Speakerholic
Cal Weldon's Avatar
Hi, your IP address doesn't seem to match your flag but either way you seem to be far away. Too bad, I could set you up with just what you need. How big can these cabinets be and what is your budget?
A single 9" or 12" will simply not do. You must think big young man.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 6th March 2011, 07:25 PM   #5
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
They will be to cheap for your taste but what sounds better than a nice paper cone with the right surface.
You really shout try if you like it, because it doesn't cost a lot. 95dB 1w meter quit loud to. The port response shout be added to the show response then you have flat down to 30 hz and reponse down to 20hz -8db
parralel 2 of these and it will rock the house.
http://www.daytonaudio.com/lspeakers...-8_295-325.pdf
Wil match nice with a accuton 93dB 1w meter basmidrange. accuton® Carefully selected loudspeaker drivers.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 6th March 2011, 07:48 PM   #6
here is a dual Volt3143/dual ATC mid and dual SS9700(one rear fire)
thanks John
Much of this stuff is DIY and it does Rock and Blues, both kinds of music. DualTriode Music 0 20th February 2011 07:23 AM
Best full range designs suited to rock music? wixy Full Range 12 2nd December 2007 03:49 AM
rock music and SE? jarthel Tubes / Valves 16 25th June 2007 11:20 PM
What should i tune my tempest to for rock music? clipper10 Multi-Way 9 16th May 2003 10:48 PM
Page generated in 0.07976 seconds (75.73% PHP - 24.27% MySQL) with 11 queries
