Is there a set rule on how to wire the phase of a tweeter mounted on the rear of the enclosure? The driver is a pure ribbon crossed with a single 2.2 uf capacitor.
The freaks stick together, they are a tight old crew |
#2 |
I assume that the way from the rear tweeter around the side wall to the front edge of the box is more than 10". Then it (almost) doesn't matter whether you connect it in-phase or out-of-phase to the front tweeter. Try both cases and decide which sounds better to you - if you hear a substantial difference.
Rudolf
www.dipolplus.de |
#3 |
Yes and thank you. That is what I needed to know.
#4 |
I think the idea would vary from system to system. If you've got a monopole connect it so that the rear wave added in by the tweeter would be in phase with the signal from the front. And if you've got a dipole connect it so that the signal would be out of phase with the signal on the front.
Of course in a situation like this, any talk about phase, when small wavelengths and large path differences and boundary effects are involved is almost pointless to the point where what Rudolf suggested is most likely the best thing to do!
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
| Motor mounted phase plug | trusound | Multi-Way | 7 | 25th November 2010 03:15 PM |
| Tweeter not quite mounted flush | samtny | Multi-Way | 17 | 30th January 2008 01:32 AM |
| Rear mounted ambience drivers, opinions? | ptwining | Multi-Way | 5 | 20th December 2007 04:41 PM |
| Coaxially-mounted tweeter? | Consul | Multi-Way | 5 | 14th April 2007 03:05 PM |
| rear firing tweeter - why? | bbaker6212 | Multi-Way | 5 | 25th September 2002 12:50 PM |
| Page generated in 0.06661 seconds (73.01% PHP - 26.99% MySQL) with 10 queries |
