Old 2nd March 2011, 05:46 PM   #1
Default Mission 717 Speaker Set
Rec'd a pair of these in dire need of repair
Both x-overs have broken ferrite inductors - these may be required to be replaced
I have one bass/mid driver - all the other are missing
Appears this driver has the glue bond attaching the magnet to the frame has dried up,
cracked and detached - obviously adhesive didn't age very well
Also, one of the cabs mitre joint to the base of the speaker is beginning to separate
This will require repair also
Q - what would be suitable for a complete driver (bass/mid & HF) replacement?
Suggest same problems with glue
Q - Can someone supply (indicatively) the value for the broken inductors?
Albeit if I get a complete new driver set - the x/over will have to change
I see per post
Damaged Mission 717 tweeter
suggestion for HF units
Any help and suggestions appreciated
Old 3rd March 2011, 09:00 PM   #2
kipman725's Avatar
Send a message via MSN to kipman725
mission stock replacment drivers at ok prices. Cost 17GBP for a new woofer for 760's, just get in touch with them.
Old 3rd March 2011, 10:09 PM   #3
Thanks for the info
Have tried to use the contact form as well as the support form
None of these work and that is in two browsers
Will try to contact them by telephone
Note, these are very old speakers - may be a problem sourcing drivers
Any other suggestions appreciated
Thx
Old 4th March 2011, 06:47 AM   #4
Inductor's Avatar
JamesEWilson,
After google, more info here
Mission 717. - AudioKarma.org Home Audio Stereo Discussion Forums
eshop - Speaker Spares - Mission
Old 4th March 2011, 11:28 AM   #5
Seems these will be hard to come by.
The vendor no longer supplies 717 drives and
the advertised replacement (I think) is not suitable.
I have sourced Beyma 8M70
http://www.lmcaudio.co.uk/assets/pdf/beyma/8M70E.pdf
The outside dimension are a perfect fit.
The PCD is 1mm out.
Work will be required with the cabinets as this unit has a baffle depth of 7mm.
By my reckoning, the cut depth for the old Mission drivers is 3.5mm +/- 0.25mm
These are rough calcs - will need a set of calipers to make sure.
Seems the Beyma drive units are better specified than the Mission
pressed steel unit in situ.
Will next need to review suitable HF units to match.
Any suggestions?
Speaker delayed insertion, speaker protector, off set sensor destroyer X Solid State 34 17th June 2011 03:07 AM
New Flat Panel Speaker 2x2 speaker set for sale (3800 sets) Tenacious Vendor's Bazaar 0 18th June 2010 12:17 AM
Mission Speaker Spares Blue_Max Multi-Way 4 11th August 2008 01:05 PM
Damaged Mission 717 tweeter David McArthur Multi-Way 1 5th January 2008 04:18 PM
Mission M72 speaker Mantronic Multi-Way 5 28th July 2003 07:07 PM
Page generated in 0.08748 seconds (74.68% PHP - 25.32% MySQL) with 10 queries
