After about one year of research I have decided that I would under take the following project:
Separate bass cabinet with 15'' woofer for 35hz-500/600hz -cornscala style cabinet + Radian 850/950pb or fital Pro hf200 in 250hz diy Edgar wood horn I need your help / suggestion on the following area: 1. I can not source k33/e or Bob Crites woofer, only this woofer is available locally Ahuja Sound Solutions would it be suitable, if not what change I should make to the cabinet! 2. In your opinion which one is better CD 850/950pb or FP HF200 in 250hz Edhar 3. Any suggestion for 2 way passive crossover? I will use my home made 300B SE mono amps to drive the above with 5 watt output at Zo 2 ohms. Thanks, pls help -Regards |
| Split Feedback | sdman | Solid State | 26 | 22nd May 2002 08:16 PM |
| Page generated in 0.05923 seconds (64.06% PHP - 35.94% MySQL) with 10 queries |
