Hello all. I hope someone has an old set of Sound Dynamics 100S speakers. They are the ones that handle 60Wrms, have a 4 ohm 10" woofer and a spun aluminium cone on a phenolic tweeter, which is about 6 ohms from memory.
I have recently re-boxed mine and stuffed up the x-over. I have kept a photograph of the crossover and can replicate it, but I need to know which couloured wires go to which spade connectors on what drivers. I already know the component values and the rest of the wiring but. The wires coming out of the standard Sound Dynamics crossover are; Red, Black, Blue and Yellow. But which goes to Tweet+, Which one goes to Tweet-, Which one goes to Woof+ and which one to Woof- ???? I will thank you in advance because I know it's a bit of a hassel pulling the drivers out. Here is a picture of the original crossover that I wish to replicate; Cheers and bye for now, Phil Elliott |
#2 |
With a closer look at the wiring, or if you could draw a schematic, it would be easy enough to guess. Tweeter polarity would need trial listening or measurement.
#3 |
Hi there Allan, I'm in Devonport Tassie. I will get back soon with a schematic, But as I say, the polarity is the issue. This is a very different crossover that worked well, and I wish I never messed around with it!
Cheers mate, Phil Elliott |
#4 |
I'm in central western NSW. It shouldn't be too hard to tell what the polarity is meant to be.
#5 |
I had a mate that worked on the Cotton up that way, in Narrabri. I will get back soon.
#6 |
It may look like there's no filter for the woofer - its probably connected directly with the black (-) and red (+) wires. Tweeter should be blue and yellow.
dipoles dipoles dipoles dipoles dipoles dipoles dipoles dipoles and dipoles |
#7 |
Hi there Stig, sounds feasable, I will take another look now. Greetings and salutations from Tasmania.
Bye for now, Phil Elliott |
#8 |
HI stig. here's a quick draft. Can you describe the signal path or even the type of crossover? Does it look 'RIGHT' to you?
My experience is limited to simple 6db/oct filters and haven't seen this one before. What do you reckon? Cheers and bye for now, Phil E. |
#9 |
This looks right to me!
Woofer is connected directly without crossover, and the tweeter is using a 3rd order (18 dB/oct) filter with a series resistor to attenuate the tweeter a little bit.
#10 |
I agree with Stig. Now try the tweeter in both polarities. If you can't pick the best one, let us know.
| LA Sound Sunset 100S | Dr Zeus | Car Audio | 9 | 24th December 2010 07:00 PM |
| Energy/Mirage/Sound Dynamics/Image Speaker Parts/Drivers, LARGE Selection! | ungie | Swap Meet | 28 | 7th February 2010 03:44 PM |
| Krell KSA-100S HELP!! | ej22g | Solid State | 0 | 15th February 2008 05:02 PM |
| Newbie Revive Sound Dynamics 1200 SMT's | ddanbo | Multi-Way | 0 | 15th January 2006 08:02 PM |
| Anyone Tweaked the Sound Dynamics RTS-3 | tvr2500m | Multi-Way | 5 | 9th January 2006 01:56 PM |
| Page generated in 0.10228 seconds (80.51% PHP - 19.49% MySQL) with 11 queries |
