Will this work?
trying to use two 4 ohm drivers...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#2 |
I'm thinking it will short W1 down to DC.
#3 |
yep, It won't work....
I think I'm either going to have to go 2 way, or Bi-amp (trying to go 2.5 way with 4 ohm drivers)
#4 |
wire both drivers in series and apply standard BSC circuits (inductor+resistor in parallel connected to load). Alternativly 2nd order low pass one of the drivers such that it corrects the baffle step, down side of this is presenting an efective 2ohm load at bass frequancies to the amp.
#5 |
Hey !!!
![]() But ,excluding the tweeter , I was wondering about two (equal ?) 4 " ,one boxed (TL) and the other on top (OB ? ). Of course the (eventual ) series crossover between the two would take into account for BSC . |
#6 |
frugal-phile(tm)
I've struggled with just 2 FRs in series. With a typical voltage source amp, you get one driver rolling off up high, but below cutoff you have an 8 ohm speaker with x watts output. Above the cutoff you have 4 ohms so amp output is ~2x watts so the SPL levels above & below cutoff is ~ the same. You do have less cone excursion & 2x the Sd below cutoff.
Now if you have an amp that has approx the same output into 4 or 8 ohm (ie a typical transformer coupled tube amp), you get 3 dB extra below the cutoff from the doubling of the drivers. So lets say it works if you have a tube amp since 6 dB BSC is too much. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7 |
Mmmmhh.I changed my mind
![]() Maybe ...1.5 way ,with a very strong notch on some driver |
#8 |
frugal-phile(tm)
... and to finish my post... if you have a current amp, you get full 6 dB BSC
dave
#9 | |
Gotta try it !!
For 1.5 way ,it may be interesting of having two equal drivers, different modded ...
| Three 10" 4Ohm subs, wired in series or series-parallel? | Nagamitsu | Car Audio | 24 | 10th May 2009 03:24 AM |
| BSC help | flippinjaz | Full Range | 1 | 20th February 2009 02:24 AM |
| Series BSC? | PeteMcK | Multi-Way | 20 | 4th September 2008 03:12 AM |
| Quality of Hammond 300 series power transformers compared to 200 series? | G | Tubes / Valves | 8 | 21st September 2003 02:27 PM |
| Page generated in 0.11374 seconds (79.89% PHP - 20.11% MySQL) with 11 queries |
