Driver with Underhung voice coil can to be good for bass as Overhung voice coil? Voice Coil Heigh - 16mm HE Magnetic Gap Heigh - 6mm give x-max of +/-5mm. Or Voice Coil Heigh - 5.5mm HE Magnetic Gap Heigh - 16mm give x-max of +/-5.25mm. The drivers is 150W RMS power. Anybody can help please? Thanks. |
#2 |
I think coil copper volume and surface area will be a significant determination of power capacity which will drive up the volume of the magnet structure for a given speaker with underhung motor. In woofers the increase in cost may not be offset by any meaningful increase in performance. It does have some neato factor.
#3 |
there is often a loss of sensitivity/efficiency with underhung
but not always very long Xmax overhung aint too good either, in that respect but I guess its possible make underhung with high sensitivity, keeping Xmax very low many modern tweeters are underhung all about compromises no two people want the exact same driver, and part of the problem so, many drivers are made more 'flexible' that they may actually need to be many other good drivers are the opposite, with much too little safety margin unfortunately probably some good ones, or would have been |
#4 |
or with a very big magnet and gap length! |
#5 |
Thanks,
The two driver is Morel Carbon: https://www.madisound.com/store/prod...oducts_id=8485 https://www.madisound.com/store/prod...oducts_id=8474 The SCM634 is a "midrange" but with WinISD the bass is better from SCW636. Idea? |
#6 |
Are you talking midbass or subwoofer?
The fact is, if two hypothetical drivers had identical T/S parameters and soft parts, except that one was overhung and one was underhung, they would perform largely the same. The only difference might be that the underhung motor might have less distortion based on a more constant Le over excursion (Le/x), and often flatter BL over excursion (BL/x), too. Underhung drivers can also be made to have the least possible moving mass because the entire voice coil contributes motive force all the time, not just a fraction of winding as in an overhung driver. These benefits accrue mostly in the midrange, which is why underhung subwoofers are so rare. The main downside of underhung is the materials cost of the huge magnets and flux return circuits that can be required to hit BL and Xmax targets. In the end, though, when making performance comparisons, it's not very useful to generalize. There are very well-made drivers in both topologies. You have to evaluate the performance if each on a case-by-case basis. Edit--oops, others beat me to the post, and I see you're talking about specific drivers... Interesting how close their specs are! It almost looks like Morel used the same parts for both, except for the top plate and the voice coil. Last edited by Bill F.; 2nd March 2011 at 01:41 AM. |
#7 |
they really are underhung
not many of those around, interesting well, the one you claim will have the better bass response it also have the lower SPL sensitivity often goes that way bloddy hell, 3" voice coil for a 6" driver typical Morel |
#8 |
If I had my own speaker manufacturing company.
1) all woofers would use a NdFeB differential drive motors - very linear - very low distortion for bass - low inductance without copper sleeve flux reduction - acceptable Mms for bass - cones would be carbon_fiber/kevlar loaded paper - I believe the basic 1984 patent has expired, but new "extended" patents exist http://www.jblpro.com/catalog/suppor...1253&doctype=3 2) all midrange would use a radial NdFeB underhung motor with full copper sleeve on the pole piece - very linear and very low distortion - very low Mms - low inductance - cones would be carbon_fiber/kevlar loaded paper 3) all tweeters would be NdFeB HEIL or advanced Ribbon designs - Beyma TPL 150, RAAL 150-10, DIY ribbon. - capable of both monopole and dipole radiation pattern - waveguide can be added to HEIL, but not ribbon - avoids the multiple distortion effects of compression driver on horns. - superior SPL vs. freq, distortion, and polar response: wrt dome or horn (you can DIY a $400 RAAL ribbon for about $70) google "Measurements performed on 16 horns" - reflected waves - defracted waves - high order modes |
#9 |
#10 | |
| How can an overhung voice coil produce good sound? | goldyrathore | Multi-Way | 50 | 26th May 2009 10:33 PM |
| corroding voice coils | pdan | Full Range | 15 | 30th August 2007 01:11 PM |
| Voice coils - too many, all must go. | Toddy Audio | Swap Meet | 3 | 31st December 2003 03:46 AM |
| Dual voice coils | Opie | Multi-Way | 1 | 19th December 2002 04:38 PM |
| Page generated in 0.12142 seconds (75.54% PHP - 24.46% MySQL) with 11 queries |
