OK, I bought for small money these old homemeade speakers, mainly to have fun seeing if I'd get lucky as to what was in them. Opened up one and found a cubic yard of fiberglass, and some pitiful drivers, including this old Oakton woofer marked "12 watts max program material." I felt discouraged, and didn't open the other one.
Until yesterday, and when I did I found a different and better woofer (of course, different strongly implies better in this case....) Anyway, it's a Utah of some weight, see attached pics. It was suggested to me that here I might find someone with sufficient lore to tell me What This Is, and Is It Good, and Where's the Data, etc. Also, is it worth while looking for another one, and will I ever find one if I do? |
#2 |
Speakerholic
That woofer is a full range unit. Looks like a cast basket for sturdiness, an inverted cloth surround and a small motor allowing it to be used in an open baffle. Too bad they cover the ceramic magnet with a "shield" to prevent you from seeing the real size.
Utah goes way back and is a respected company. Might be hard to find another though. Check the usual places. Is it 12"? |
#3 |
Speakerholic
Look in the upper left corner
utah blue frame speaker full range - Google Search Utah went on to become Pyle AFAIK. |
#4 |
Thanks! Mine, like the first ones in the thread you point to, has no sign of ever having the tweeter in the middle. So that just makes it an extended-range woofer. Which just might be really neat....
That pic in the first message in the AK thread of the front of the cone has a fascinating optical illusion to it. Perception can 'switch' and you see it on the left instead of on the right, with a concave middle. |
#5 |
Speakerholic
When it "switches" I see the cut out of the cabinet on the left is now on the outside of the driver and the whizzer cone is now inverted showing the dust cap on the outside. Is that what you see too?
Any driver with a whizzer is most often referred to as full range, wide range or extended range. Without it an extended range woofer is often referred to as a mid bass. Confused yet? |
#6 | |
In my mind, a midbass is a small woofer doing double duty not only as a woofer but also in the midrange frequencies. |
#7 | |
What I want is a woofer that gets up over 2000 hz comfortably (and of course down to 30 hz too). Doing both is the trick I guess. I need to hook it up and play with it. |
#8 |
Speakerholic
Fair enough, we all have different names I suppose. I think that one will have no problem at all with 2K. Might be a bit to ask for 30Hz though. Like you say, hook it up have a go at it. With a whizzer it'll probably go higher than a lot smaller mid basses
#9 | |
Some of the better/premium 6.5 inch midbass drivers will do from the low to mid 30's and easily to 2KHz. |
#10 |
OK, I can report it plays a 30 hz test tone nice enough. I also put it into a quickly-cobbled-together 3-way frankenspeaker, and the result wasn't too awful. Can't really judge bass performance from a leaky acoustic suspension installation in a random cabinet though.
There seem to be several AK threads about speakers a lot like these. Some disparaging remarks noted.... Nearest thing to data on these(?) speakers comes from 1971 Radio Shack Catalog, pg 41 (they branded these the 'Americana,' the names 'Pandore' and 'Celeste' are mentioned i the threads too). Cat entry says it goes from 25-20,000 Hz (but that's with a co-axil tweeter). And gives power handling as 45 watts.
| About the woofer:Passive Radiator or Double Woofer for Vetend | kevinlin1013 | Multi-Way | 8 | 12th January 2011 06:13 PM |
| WTB: 6.5" woofer to replace broken woofer in cheap band pass subwoofer | Jimmy154 | Swap Meet | 2 | 5th October 2010 02:00 PM |
| Woofer replacement for Infinity Reference 2000.5 Woofer | kchilaka | Multi-Way | 0 | 28th September 2010 05:11 AM |
| interesting amp & interesting problem | m6tt | Tubes / Valves | 9 | 14th August 2007 06:28 PM |
| Qts of Push-pull woofer and Compound Woofer System... | haggy | Multi-Way | 1 | 13th December 2001 01:30 AM |
| Page generated in 0.11821 seconds (81.17% PHP - 18.83% MySQL) with 11 queries |
