Old 28th February 2011, 08:43 PM   #1
Default Unibox quick question / driver suggestion
Hi everyone, I am just using unibox to process some frd files for later use in designing some new speakers. I am using the Seas MCA15RCY drivers as mids and i was just wondering, when modelling in unibox as a mid, do i use the 'closed box' setting and just use that at something appropriate which in this case is 2L volume?
Cheers in advance, also if anyone has any comment or opinions on these drivers that would be appreciated too, i am to pair them with some Scanspeak 18W bass units and Scan D2905 tweeters.
Andrew.
Old 1st March 2011, 07:52 AM   #2
AllenB is online now AllenB  Australia
For some purposes actual on baffle plots will be useful. I would use generic plots only as a starting point in a design. It isn't so much the rear enclosure. Your choice there is not unreasonable.
Old 1st March 2011, 05:59 PM   #3
Thanks AllenB, thats all i needed to hear. I've also plotted the drivers on my baffle design with BDS to obtain more accurate results and used the FRD combiner etc.
Old 1st March 2011, 08:05 PM   #4
You're welcome. I don't want you to think I was suggesting baffle step compensation per se. The baffle step changes the on axis sound but the same amount of sound still gets out into the room regardless, so full BSC is rarely a good idea outside of an anechoic chamber.
Old 1st March 2011, 08:53 PM   #5
Yeh no worries, i realise that since most rooms being very poor acoustically will reflect the off axis response all over the place, hence distorting the effect of BSC in realistic terms - but thanks for the tip, any advice is always helpfull!
Simple Quick Question about 6 driver line array? 8675309 Full Range 1 2nd November 2010 07:45 PM
Driver suggestion obbelix Subwoofers 10 24th October 2007 10:07 PM
Quick question about the Pioneer B20 8" driver davidallancole Full Range 10 2nd October 2007 05:08 PM
Small single driver speaker suggestion (and power rating question) percy Full Range 68 17th March 2005 06:04 AM
Quick question re: finishing up my sub enclosure & mounting driver CUclimber Multi-Way 1 18th April 2004 06:46 AM
Page generated in 0.07257 seconds (84.55% PHP - 15.45% MySQL) with 10 queries
