Old 27th February 2011, 11:15 PM   #1
Default speakers near the rear wall
I know you're not supposed to place speakers near the rear wall, but if you have no choice, is there any way to mitigate the consequences? I'm thinking of absorbing panels of some kind; something that wouldn't look too bad unless there are other options. My problem is especially bad because they will be open baffle. And yes, cost is a factor.
Old 28th February 2011, 12:58 AM   #2
CLS is offline CLS  Taiwan
What 'consequences' ? What do you get ?
Old 28th February 2011, 01:11 AM   #3
aptquark's Avatar
In many situations, having them close to the wall can be a good thing. But it depends on the room.
Old 28th February 2011, 01:37 AM   #4
tinitus is online now tinitus  Europe
not optimal, but might work ok
I did that for a few years
but no closer than 1-2 feet(50cm) to back wall
hell, you could try to lean the baffle up against the wall
even that may work, maybe even better
Old 28th February 2011, 01:45 AM   #5
Conventional speakers away from the wall may sound less boomy. But it's not just the rear wall, it's all. Try to get different distance to rear wall, floor, ceiling, and to the side walls, and to the other speaker. That keep resonances from reinforcing each other.
Now, open baffle is a different story. But I think you are contradicting your own aims. Open baffle is usually trying to get an "open" planar-like sound...but part of that whole deal is NOT being near walls which will make reflections close on the heels of the frontward radiation. You could put absorbent material all over the wall behind them, but it will only work from the midrange up (IF you buy GOOD material) and it really kind of defeats the purpose of having an open baffle speaker at that point. If you're absorbing the rear wave, you might as well have an enclosure, eh?
Old 28th February 2011, 02:28 AM   #6
Okay, I guess I get the idea. Maybe I'll have to rearrange the whole situation because I do want to try OB's.
Do you think that sweeping the room with REW and an appropriate DSP EQ would help a situation like that?
SSB4 reflex project: massive amount of rear wall absorbent!!! mondogenerator Multi-Way 2 5th November 2009 11:09 PM
So, why not in-wall speakers? wigginjs Multi-Way 4 20th August 2007 02:59 AM
Rear speakers, yes or no? MatthewR6 Car Audio 14 23rd June 2004 02:59 AM
searching software to switch front speakers to rear and rear to front!-dolby surround MCM Everything Else 6 6th February 2004 09:29 PM
Page generated in 0.08115 seconds (72.69% PHP - 27.31% MySQL) with 10 queries
