Just wondered what are the best proportions for a rear loaded horn design to reduce ripple and have something that is fairly compact too.
Thanks Boscoe
I thought about it once, but then thought again. |
#2 |
compact horn must produce ripple..
(corner) placement can help to reduce
flesh flash flush |
#3 | |
Corner placement does theoretically the horn increase mouth size and there for horn-loading = acoustic resistance. This will flatten the response in some degree.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#4 |
By compact I mean about max total volume of 150l.
#5 |
That shout be enough.
http://www.fostexinternational.com/d...6e_enclrev.pdf
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 25th February 2011 at 07:30 PM. |
#6 |
I actually already have the drivers I would like to use. The Monacor SPH-210.
#7 |
It is not a good driver for a horn due TS-parameters.
#8 |
my (in process)150 l w\o rear chamber
front load, pi & 0.5 pi
flesh flash flush |
#9 |
What sort of parameters am I looking for?
#10 |
Best drivers for horn loading are basMID drivers with Fs of around 60Hz.
To see fast if a driver will do good do Fs/Qts if the result is around 110 it is a indication it will do a good job. Simulate it in horn response. Like the monacor sph-176. Here a 100litre backloaded horn. Combined response of direct radiation and horn radiation in a corner placement. Horn mouth response
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 26th February 2011 at 07:02 AM. |
| Just a rear loaded horn question. | Boscoe | Subwoofers | 0 | 25th February 2011 05:16 PM |
| Pimping your rear-loaded horn. | milesian | Full Range | 7 | 16th February 2011 08:14 PM |
| rear loaded horn | farriswheel | Car Audio | 2 | 27th July 2007 05:03 AM |
| Rear Loaded Horn | David R. Carlso | Full Range | 3 | 9th January 2006 10:04 PM |
| rear loaded horn question | zobsky | Multi-Way | 5 | 21st September 2004 08:13 PM |
| Page generated in 0.10166 seconds (76.93% PHP - 23.07% MySQL) with 11 queries |
