Old 25th February 2011, 05:26 PM   #1
Default Audibility of Crossover Point
So ... I'm thinking of the Beyma hon tweeter, and a decent Seas 8" driver.
Directivity at about 1kHz should be a reasonable match, I can use an active crossover and be quite steep and/or use a 2nd order passive on the Beyma (I figure it needs some inline cap at least for protection).
So the integration is at least theoretically possible if not trivial.
But I'm concerned - perhaps for no good reason - about a cross there rather than away from the voice area, such as I might get with a 3-way. I used to love the ATC mids in some old proacs I had once. And as a counter-example some of the reference designs for the Excel tweeter cross pretty low.
Should I just Go For It?
Was thinking CA22RNX (I think that's the right one!). Maybe the Excel not sure.
Old 26th February 2011, 02:02 AM   #2
AllenB is online now AllenB  Australia
The ear is quite sensitive at 3-4kHz. In my opinion, that is the region to avoid. 1Khz can be made to work. If you have a directivity match there, that may be the best choice.
Old 26th February 2011, 03:30 AM   #3
Pano is offline Pano  United States
Pano's Avatar
I've used a 1KHz crossover point a few times. It can be done. But, wow, every little change you make to it - you can hear.
At least you won't be wondering if what you did had any effect.
Take the Speaker Voltage Test!
Old 26th February 2011, 04:14 AM   #4
I agree with Pano, a crossover at 1KHz is totally do-able, but you will find that the final result will be quite sensitive to the XO:
- Slope
- Frequency
- Impedance correction for the tweeter
- Zobel correction for the woofer.
So what is new I hear you ask? Sounds like a typical list of crossover issues!
Choosing 1KHz is getting perilously close to most tweeter resonant frequencies. This mans you will have to control these very well.
I get the impression you are thinking of using a horn. Not sure which, but 1KHz is getting low for many horns - watch out for this if I understood you correctly.
Most 8 inch drivers can be pushed well beyond 1KHz, you might find there is a better compromise between toe woofer and tweeter somewhat higher. If there is not, can you consider a midrange ???
Old 26th February 2011, 04:23 AM   #5
Pano's Avatar
True, I don't know why you'd need to cross an 8" as low as 1Khz, unless it was meant for sub duty or something.
Old 26th February 2011, 05:29 AM   #6
frugal-phile(tm)
planet10's Avatar
Because you could. 1 K XO usually easier to live with than 2-4k
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 26th February 2011, 06:19 AM   #7
Here's where 1kHz is a different story with dome tweeters whose impedance at resonance will hamper tweaking of the crossover, and excursion will be limited.
Old 26th February 2011, 02:04 PM   #8
This will be active (and DSP) so I'm not expecting to do any impedance correction, although I might have 1st or 2nd order highpass in analogue to protect the tweeter.
The horn in question is this one: http://profesional.beyma.com/ingles/pdf/TPL150H.pdf
Much above 1k, the directivity of the 8" will start to match badly won't it?
Also there's the possibiliy of using the Excel 8" and being that much further from the cone going nuts above 4k.
Old 26th February 2011, 03:02 PM   #9
gfiandy is offline gfiandy  United Kingdom
Audio Engineer
gfiandy's Avatar
With a 102dB sensitivity tweeter my concern would be avoiding audible hiss especially if you are going to drive it directly from a DSP and amplifier.
Unless you have an outstanding DSP and amp you may need to use passive pad just to reduce the noise floor.
This is assuming this is for a home environment.
If you are planning a high quality pro system then this is a great choice of tweeter but then the bass speaker is then not suitable as its efficiency is too low for a pro system.
Andrew
Old 26th February 2011, 09:35 PM   #10
Do you have a directivity plot for the tweeter before you condemn your crossover point?
The sensitivity seems like a waste. It can be done if your mind is made up, but this is an opportunity to use a pro woofer.
Crossover point wiredmonkey Multi-Way 1 12th May 2008 10:57 AM
Can you hear the crossover point of a speaker with a well-designed crossover? 454Casull Multi-Way 11 2nd April 2004 05:48 AM
Point to point crossover soldering Ilianh Multi-Way 9 24th December 2002 04:14 AM
A better crossover point Westrock2000 Multi-Way 9 26th October 2002 05:13 PM
Sub crossover point AudioFreak Multi-Way 2 31st December 2001 11:33 AM
Page generated in 0.10580 seconds (81.36% PHP - 18.64% MySQL) with 10 queries
