Old 25th February 2011, 03:38 PM   #1
cs is offline cs  United Kingdom
Default Polypropylene coned drivers
I have always liked the smooth sound you get with polypropylene coned woofers, such as those used by Spendor, for example.
Does anyone know of a source for such drivers, for DIY use ?
A size in the range 15 to 17cm would be ideal.
Old 25th February 2011, 04:40 PM   #2
Default Monacor
Look on Monacor's web-site.
They manufacture drivers with cones of various types, and of good quality,
including some drivers which are designed to replace some of the ones in the better quality vintage l'speakers.
Visaton may be making some also.
Alan
Last edited by alan-1-b; 25th February 2011 at 04:42 PM. Reason: to add a sentance
Old 25th February 2011, 06:37 PM   #3
DDF is offline DDF  Canada
DDF's Avatar
The Scan 8543 is the best poly I've heard or used. I have years experience with it. If you like poly, you won't be dissapointed with this one.
Old 25th February 2011, 06:56 PM   #4
Hi DDF!
Can you share some of your experiences with the Scan Speak 8543 in regards of suitable tweeters and crossover-design? I'm a huge fan of simple first order x-overs. Is the 8543 capable of that?
Regards!
Martin
Old 26th February 2011, 02:12 AM   #5
DDF's Avatar
Originally Posted by martinbls View Post
Hi DDF!
Regards!
Martin
Hi Martin,
For Poly, it is somewhat stiff. This gives it good detail but also shows up as a high q resonance around 5 kHz. Because of this, and after trying over a dozen iterations, I felt it wanted an RC electrical second order + RLC series shunt for the peak.
In a 10"wx18" high faced box (driver center 7.5" from bottom), it measured as attached at ~ +5 deg vertical. You can see the break up requiring the trap.
I think this was used in the Pro-ac response 2s in the early 90s. I bought the woofer in '91 and used it for ~ 10 yrs.
Markk measured it here and found the midrange distortion "remarkable". I still like the 8545 better but this driver has a special place for me since its very smooth and has a nice "dark" but detailed sound when worked correctly.
7 inch driver test results
For tweeters, I would recommend your favorite soft dome. I think an Usher9950 or Dayton RS28F would be good bets. I ran it with a Scan 9300 but this was almost 15 yrs ago and I'd favour more modern tweeters over it now.
Dave
Old 26th February 2011, 02:17 AM   #6
DDF's Avatar
Weird post editor here at DIY, it blew out the attachment. Here it is again.
Old 26th February 2011, 11:48 AM   #7
Hi Dave,
thanks a lot!
Looks like the 8543 is not as smooth as other polycone drivers, so a bit more work on the crossover might be on the to do list...
Martin
Old 26th February 2011, 12:11 PM   #8
jmsent is offline jmsent  United States
Have a look at the SEAS U18RNX/P.
THE ART OF SOUND PERFECTION BY SEAS - H1571-08 U18RNX/P
It's a woven poly cone, with very linear and extended response.
Old 26th February 2011, 03:34 PM   #9
I agree, I used it in my last speaker; furthermore totally able to be used with a 6db slope because of the well-damped cone break-up. In french language but you can see some measurements of this speaker here:
VOKALIST monitor 2-voies: ça y est, elle chante!!! - Enceintes
CSD (at -40dbs !) of the U18 without filter, very clean:
.frd of the wave-guided 27TDC and (bellow) the U18, without filter but on the Vokalist enclosure; the slight dip around 2.5khz is enclosure diffraction related:
crazyhub
Old 26th February 2011, 10:30 PM   #10
DDF's Avatar
crazy hub, can you please repost these? They don't seem to want to expand, for viewing
Polypropylene caps liberty Tubes / Valves 21 31st August 2009 06:04 AM
Can Ted Jordans Drivers be re-coned? DawgNo1 Multi-Way 10 12th January 2009 10:07 AM
Polypropylene versus metallized polypropylene VS Parts 8 15th April 2006 05:36 PM
Paper coned Excel woofers michael Multi-Way 4 12th January 2004 02:55 PM
Efficient Paper Coned Drivers Jack Thomas Multi-Way 13 30th September 2002 07:37 PM
Page generated in 0.10609 seconds (79.31% PHP - 20.69% MySQL) with 11 queries
