Old 24th February 2011, 06:54 PM   #1
Default Speaker stands from reinforcing steel?
Hi guys,
I'm thinking about building speaker stands welded together from reinforcing steel. What are the potential problems and (how) can they be solved?
The stands would need to carry two different types of speakers, 11kg and 26kg.
Thanks.
Markus
Old 24th February 2011, 07:20 PM   #2
sdclc126's Avatar
Tube or solid? Round or square?
Do you have all the necessary tools and skills?
Old 24th February 2011, 07:26 PM   #3
I'll have a pro that will do it for me.
Markus
Old 24th February 2011, 07:36 PM   #4
sdclc126's Avatar
Oh OK - we call it "rebar" here in the States.
What sort of problems did you think you might have? I can only think of the possibility of the bars vibrating, but i have no idea if it would be audible - my instincts tell me it won't be.
However I'd recommend you not place the speakers directly onto the metal - make bases out of mdf and place the speakers on those, either with isolation spikes or rubber feet, etc. You should probably do the same thing at the bottom, but that depends on what the floor is made of - solid or carpet.
Old 24th February 2011, 07:49 PM   #5
It will be hard to avoid making a mechanically low loss structure out of this material. Maybe if you finally cast it in rubber or something.. Concrete?
Old 24th February 2011, 08:05 PM   #6
tinitus is online now tinitus  Europe
scatches on your speaker's finish
and, best not to have too much iron close to Xover
and needs a complicated construction to make i stable
hmm, might look special with lots of it welded close together side by side
and it would be stable
Old 24th February 2011, 08:13 PM   #7
I'd like to have it as lightweight as possible but the questions is if a rather flexible construction with rubber damping between speaker/stand and stand/floor is desirable?
Here's an idea how the stand could be decoupled from floor and speaker:
Markus
Old 24th February 2011, 08:33 PM   #8
sdclc126's Avatar
No reason for them to be light weight - they should be robust and relatively heavy.
Old 24th February 2011, 10:10 PM   #9
The worst case scenario would be a speaker hanging from the ceiling. Is this detrimental to the speakers performance?
Markus
Old 24th February 2011, 11:03 PM   #10
dantheman's Avatar
I prefer mine to be heavy just for safety. Don't want them to get knocked over.
Dan
My Blog
My Music Recordings
Speaker Stands jleaman Multi-Way 3 5th May 2007 12:18 PM
Speaker Stands dswiston Multi-Way 2 2nd June 2005 06:00 AM
Sub inside speaker stands? yepper Subwoofers 1 25th February 2005 11:18 PM
Speaker Stands? AJ Bertelson Multi-Way 5 22nd May 2004 02:57 AM
Speaker Stands robv60 Everything Else 30 26th March 2003 02:00 AM
Page generated in 0.11584 seconds (74.78% PHP - 25.22% MySQL) with 11 queries
