Old 24th February 2011, 04:28 PM   #1
dede is offline dede  France
Default TAD 1201 horn ?
Hello,
I've got a pair of tad 1201 waiting to be used between a 1601 and a tad 4001 in iwata 300 horn.
But i'm wonder if i should use them in direct radiation or in a horn. And if so in wich horn ?
Thanks for your input
Anthony
Old 25th February 2011, 12:44 AM   #2
CLS is offline CLS  Taiwan
IMHO, you'd better leave the 1201 for another project, and find a supertweeter for 1601+4001.
Old 25th February 2011, 01:37 AM   #3
limono is offline limono  United States
I think that 100-130Hz tractrix (can be a squared one) with 4" throat would sound cosiderably /miles better than 1601 in midbass range. I had it in 202Hz Azura horn crossed at 500 to td4001 in Edgar tractrix and it was very good. You will need to address TAD 4001 HF somehow in the future but don't let be talked out of the upperbass/midbass channel. It is the most important channel and if you get it right you'd be ahead of 99% 15"+tuba speakers.
Go to GoodSoundClub - Romy the Cat's Audio Site infamous Romy site and there is a scandinavian's guy midbass project with 1201. Good luck!
PS There is probably only one tweeter which would match TD4001 -ET703
Fostex t500mkII is very sweet sounding and I liked it more than somewhat bland sounding ET703 with JBL driver but didn't have chance to try it with TD4001. Lastly, you have to be sure and honest with yourself that sonics produced by TAD compression drivers are what you're looking for and willing to invest quite a bit money and a lot of time. 1201 is pretty safe bet -it sounds stunning in midbass horn but compression drivers are controversial ,merciless sounding SOBs and I'm putting mine back on the shelf untill I learn how to use them (I have 1201,4001,703 with custom round horn)and find room/house for 6 channel setup!
Old 25th February 2011, 05:18 AM   #4
Gluca is offline Gluca  Italy
tarmac ripper
Gluca's Avatar
For your consideration
Yuichi's Audio Lab.
It seems to me that 4001 can handle easy 500-20kHz. I'd stay with the 1601+4001 combo and actually that is what I will build this summer. I'd save 1201 for something else or sell it to buy a supertweeter.
Old 25th February 2011, 06:55 AM   #5
hello,
Thanks for your input. I currently using The tad's in two ways but i found the 1601 à little bit lifeless above 350 hz.
The plan Is indeed to add an et703 asap and a tl-1801 à little bit later when i will be in my new house.
What ti you think of that Horn ?
hornplans.free.fr/m17.html
regards
anthony
Old 25th February 2011, 07:33 AM   #6
tarmac ripper
Gluca's Avatar
With that horn you will definitively need a subwoofer. I am not a big fan of mutliways, my preference goes to two ways with maybe a tweeter to add the 'finishing touches'
What cabinet are you using for 1601 and at what frequency are you crossing?
gianluca
Old 25th February 2011, 07:39 AM   #7
So far The 1601 are in a 130l reflex box.
The crossover is 650 hz 18db
anthony
Old 25th February 2011, 08:38 AM   #8
revintage's Avatar
You can, as earlier said, design a midbass horn around 1201. Beware that the published Mmd=5gr is wrong. Should be 52gr!
Brgds
Lars
Old 28th February 2011, 11:51 AM   #9
pos is offline pos  Europe
pos's Avatar
it is 60g
Old 28th February 2011, 12:23 PM   #10
revintage's Avatar
Hey Pos,
Using Thiele Small mathematics, Mmd is 52gr if we assume the rest of the parameters being right!
But it might also be so that you mean Mms=60gr and then this should be about the same as 52gr Mmd.
But if you have measured an actual driver please share.
Brgds
Lars
TAD 1201 Midbass homebuilder Swap Meet 4 8th February 2011 04:09 PM
TAD TL-1601a and TL-1201 Crossover Point manp111 Multi-Way 2 27th September 2010 07:57 PM
TAD TL-1102 vs TM-1201 or TM-1201H manp111 Multi-Way 14 3rd September 2010 09:23 AM
Tad Wood Horn Diy thanhVNS Multi-Way 2 14th October 2008 04:43 AM
Hedlund Horn using tad 1602 kartsmart Multi-Way 0 12th June 2005 11:50 AM
Page generated in 0.10073 seconds (79.67% PHP - 20.33% MySQL) with 11 queries
