Hello Masters
Just got this polk monitor 30 speaker yesterday from newegg. remove the crossover section and found out 2 electrolytic caps w/c values 18uf 50v & 8uf 50v.Can I change this to a polypropylene capacitor ? Thanks and more power to the site!!!!
#2 |
Polys will last longer and may possibly be closer to stated values. But don't expect to hear an improvement in the sound quality, if that's why you're making the change.
#3 |
Agreed. This being a DIY haven, go ahead. They may make a difference, may be better or may be worse.
#4 |
If the caps are used anywhere near the midrange and treble then you'll definitely hear the difference using better caps. And no, they don't need to be the hyper expensive ones - electrolytics just don't belong in speaker crossovers.
My religion is the golden rule. The only time it's forsaken me is when I've forsaken it first. |
#5 |
If you JUST got them, listen to them first if within a return period, eh?!
#6 |
okeythen, I'll break them first and see the outcome.
| polk monitor 70: worth any kind of upgrade or not? | linuxworks | Multi-Way | 33 | 8th January 2011 02:32 PM |
| NAD monitor series, Polk SDA2B, Eosone RSF, more. | jcandy | Swap Meet | 1 | 22nd September 2010 10:34 PM |
| New Polk Monitor 10 Configuration - HELP!!!! | boonaroo | Multi-Way | 6 | 11th April 2009 02:00 AM |
| Boston Acoustics T830 / rebuild vs change to Polk Monitor 10s | mattias | Multi-Way | 1 | 23rd January 2009 11:00 PM |
| Polk Monitor 70 Speakers | crippledchicken | Multi-Way | 1 | 20th February 2008 05:25 PM |
| Page generated in 0.07680 seconds (71.99% PHP - 28.01% MySQL) with 10 queries |
