I have to admit, I'm rather taken with the idea of a single driver setup, mainly because they are supposed to provide a better image and stage due to the pin-point source concept if they are properly implemented. I don't think I care overly much about the crossover issue, but I do like simplicity of design when it gets the job done. I'm very new to this stuff, so I need some direction here.
1. Is the above observation true about the benefit of pin-point source? 2. If so, would it be feasable to make a kind of pseudo-coaxial using a 15" or 18" speaker mounted on an open baffle (maybe an H shape) with a 8 or 10" fullrange driver mounted immediately in front of the woofer on brackets as close as possible to the woofer? A manufactured 15" coaxial speakers would be my first choice, but they are too expensive. I have a pretty large room to fill and I love a lot of good, smooth bass (not boomy, though). Think bass viol. Also, I don't need a lot of high frequency because my hearing ends at 11 Khz, but I don't want to sacrifice too much for the sake of other listeners. Suggestions? Last edited by sprinter; 24th February 2011 at 01:51 AM. |
#2 |
Well, as I think about it some more, I suppose the two speakers would just drive each other nuts, so probably wouldn't work. Just thinking out loud...
I have noticed, though, that most open baffle arrangements have the drivers pretty far from each other. What is the reason for that? Could you mimic a pinpoint source better with the drivers as close as possible, but not in tandem? |
| Small diy monitors - two way or coaxial? | wxn | Multi-Way | 7 | 12th June 2006 02:56 PM |
| a bosoz-X-CCS mic preamp Feasable???? | DJNUBZ | Pass Labs | 5 | 1st December 2005 01:03 AM |
| diy coaxial audio cable | rnzr | Digital Source | 30 | 4th February 2005 10:23 PM |
| DIY Coaxial Question | ericimage | Multi-Way | 0 | 16th May 2004 07:20 PM |
| DIY COAXIAL Cable besides Belden? | NEAR_SOTA | Everything Else | 24 | 12th August 2003 08:27 AM |
| Page generated in 0.07748 seconds (68.98% PHP - 31.02% MySQL) with 10 queries |
