I'm starting a project from Parts-Express called "Sophomores". You can find the project here: “Sophomores” writeup.... - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com I already have the 2 HiVi M4Ns and I will start ordering the rest of the parts very soon. There seems to be a lot of controversy on using x-parts in crossovers and how it affects sound etc. For the resistors. Can I use a standard wire-wound? (Not "audio-grade"?) Something like this: 280-CR25-7.5-RC Xicon Wirewound Resistors - Through Hole Just out of curiosity...What would happen if I used some 50W thick film resistors instead of the wirewounds? Secondly. As far as capacitors go, how much better do poly-film capacitors sound in comparison to non-polarized electrolytics (NPEs). Films start to get reaaaally expensive...and I'm trying to be as economical as possible. I appreciate any input. After doing some preliminary planning for the crossovers, the xovers wind up being almost 1/3 of the cost of the entire project...and that sure says something. So I'd like to make some cost cuts... Thanks. Yours truly |
#2 |
re:'resistors. Can I use a standard wire-wound?' - as long as they are non-inductive; an alternative is to parallel several lower rated metal film resistors to get the value & power rating you want
re: poly-film capacitors in comparison to non-polarized electrolytics - electrolytics degrade over time (years), but big poly caps are expensive.... I use electrolytics for values over ~ 10uf
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#3 |
Well... I had some old Advents a few years ago and these benefited greatly when I changed the crossover caps to Wondercaps (no longer made AFAIK)
As to resistors, I think non-inductive wire wound are a good choice for a crossover unless you have a way to monitor actual inductance of the assembly and can tailor the inductors accordingly. (generally you can't, so why risk adding some inductance from resistors?) So, I guess the crossover will sound as good as you are willing to make it sound. You could always build them up and then change components later if cost is a huge concern for you now...
"When the world is running down, you make the best of what's still around." |
#4 |
Alright thanks everyone. This cost of this project just keeps on growing, and I'm trying to cut back a little bit. I'm no "audiophile" by any means, though I still want it to sound decent.
#5 | |||
Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
#6 |
...truth seeker...
Maybe Wolf will pay a visit...
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#7 |
1/3 of the project cost for the crossover is not out of line. Especially with the cost of copper these days. Almost any of the budget items at Parts Express will serve you well.
Take the Speaker Voltage Test! |
#8 |
Wirewound inductance in crossovers is not that important. Typical values between 2R and 22R are not going to shift much at 20KHz
The place where it matters is the ~0R2 emitter resistors in amplifier output stages, where the inductance causes stability problems |
#9 |
Thanks again. I'll just get most of the items from Parts Express and the NPEs from Mouser.
Tomorrow, hopefully I will have everything sorted out and will make an order. Thanks again. |
#10 |
Just a quick question which I'm pretty sure I know the answer to...but I just want to be certain of. If the X-Over schematic calls for a 6.45uF capacitor, using 6x 1uF films + 1x 0.47uF film would give me 6.47uF. 6.47 is close enough to 6.45 is it not? Capacitors have a pretty big tolerance anyway so a capacitor labeled 6.45uF can be +/- 5-10%?
| Crossover part TINY BIT DIFFERENT then supposed to be...will it matter? | PoorSound | Multi-Way | 5 | 13th February 2007 05:51 PM |
| Crossover components | JC | Multi-Way | 13 | 19th October 2003 02:32 PM |
| Crossover components: what should I use? | LKS | Multi-Way | 2 | 25th September 2003 01:33 PM |
| crossover components | ray | Multi-Way | 1 | 11th September 2001 12:17 PM |
| crossover components | zach | Multi-Way | 1 | 19th August 2001 07:48 PM |
| Page generated in 0.16185 seconds (65.60% PHP - 34.40% MySQL) with 11 queries |
