Old 21st February 2011, 08:56 PM   #1
xymox1 is offline xymox1  United States
Default Scan Speak midwoof cabinet volume
OMG... While yea, I know determining a cabinet volume is a tricky buisness, I am lost on this..
Scan Speaks Toolbox needs values that the spec sheet for this speaker says a - so I dont know what to put and 0 does not work.
So...
What I want to do is get a general idea of the volume min/max I will need and then I have a way to vary this once the cabinet is done and measure / sweep and see what volume is best..
BUT I need to know what a minimum / maximum wold be for this driver..\
I would prefer to be able to caculate this myself, but this being a small driver I dont trust the caculators I found on line for car audio.
http://www.europe-audio.com/datashee...5w_8531k00.pdf
I understand the xover and all that matters obviously, but if I can get a general range for box volume I would be happy...
Sorry I am a bit frustrated as I have been at this for hours trying to work this out.. Very annoying..
Old 21st February 2011, 09:45 PM   #2
If i understand you correctly - you are trying to work out an optimum cabinet size for a particular driver? Well if thats the case, try Unibox calc sheet here - its very easy to use, you can input values manually from the scanspeak data sheets or search its own database which may or may not already have the driver you're concerned with so you wont need to manually input values.
FRD Consortium
Now for a tutorial on how to use it easily, look here -
FRD Consortium tools guide
just scroll down to the Unibox section.
Hope that helps!
Andrew.
Old 22nd February 2011, 12:04 AM   #3
Hmmm.... Your "here" link was not a actual link. The site you lised had a lot of stuff on it but im not sure its one of the ones your discussing..
Its my understanding that doing a small box aith a small driver 5-1/4" is more tricky then a large woof..
I plan on starting with MDF to play with the box and then once I am sure of what i am doing getting some Corian cut and make the whole box /bracing out of it..
My drivers, crossover and tweeter acoustic lens assm all came from a set of YG Acoustics Anat Reference 2's which i upgraded for a client and I got to keep the old stuff. The crossovers are quite nice. I am replicating the YG Design. Well I am making mini-monitors from the top section.
YG ACOUSTICS - PRODUCTS - ANAT REFERENCE ||
My general cabinet design ideas so far. I am making it so I can move a block forward and back in the cavity for each mid-bass to tune it.
http://www.xymox1.com/Junk/Speakers.gif
I would have to reverse engineer the xover to figure that out, is that nessary to work out the cabinet volume ?
Old 22nd February 2011, 12:11 AM   #4
The links are down to the program..
Old 22nd February 2011, 01:54 AM   #5
I am reverse engineering the xovers. Nice parts..
Tweeter Xover. Lots of parts. The schematic is not normal. Im gonna have to ponder this one a bit..
mid-woof Simpler..
Old 15th April 2012, 07:10 PM   #6
SDF is offline SDF
..I think drivers used by yg are customized!!!
Old 16th April 2012, 06:46 AM   #7
There's a ball park for you...
Old 16th April 2012, 10:23 AM   #8
So...
I have used this same driver with much success in 15L (1/2 cu.ft.) box. F3 in a closed box will be around 60 hz. With a vented alighment, closer to 40. hz.
FS: Scan-Speak Illuminator d3004/60200 Tweeters, Scan-Speak Discovery 10f Midrange bikinpunk Swap Meet 1 27th September 2010 03:13 PM
Scan Speak 23W and Passive with Cabinet on eBay! sbrtoy Swap Meet 1 10th September 2008 10:48 AM
Volume for Scan Speak 21W85550-01 yoke Multi-Way 24 22nd September 2007 05:25 PM
Scan Speak Revelator MTM, what volume cabinet obiwan Multi-Way 2 30th May 2007 11:47 AM
3-way Scan-Speak marvii Multi-Way 9 15th April 2007 04:14 PM
Page generated in 0.10357 seconds (78.88% PHP - 21.12% MySQL) with 11 queries
