I am about to start a new 4-way project based on some drivers I have and other ones I could get.
I was considering one of the next three options (please see picture). From your experience, which one would you choose? All drivers to be in sealed chamber except for the woofer(s) which are vented (low-side port). Thanks and regards |
#2 |
Hi Sony,
I think you shoul build a cabinet following the characteristic of your bass and mid-bass driver. I would build a separate cabinets for bass and mid bass. |
#3 |
Based on my experience and your options, I would go with #1.
BUT, As GoranB suggested, an even better (not listed) option would be to have separate bass/mid bass/ and main array cabinets. |
#4 |
I would prefer A
but make the mid/heights as open baffle subwoofer as you wish closed or ported, make it smaller and hide it B is ok C is ugly! |
#5 |
make it as modular as possible : easier to offset the drivers, and further experimentation allowed
#6 |
Thank you everyone for the great tips.
I understand the multiple modules motivation, but the Beyma 15B100/R on vented configuration needs a 160 to 190L volume enclosure, making that impracticable. It can be done if used in a sealed box. - On vented configuration 190L box it's at -3dB at 40Hz; on sealed 100L box it's at -3dB at 55Hz. Since it is a 97dB unit, sealed is a viable if crossed really low and mid-bass units also work in the sub-bass. I mean, making it a 3.5 way and not 4 way design. So, under your guidance I got to these 3 new possibilities (see new picture). First one vented 4-way, 2nd and 3rd designs sealed woofer 3.5way. Design of these last two can be improved. Option 1 has to be a large box to provide space for the 15" woofer in vented configuration. Please vote.
#7 |
I like the design Nr.2
What about crossovers for all these drivers? You should do a lot of math |
| Focal 2-way crossover design options | focal7C | Multi-Way | 4 | 20th August 2008 02:56 AM |
| FR125 New Design Options - Feedback Requested | ABS | Full Range | 74 | 17th October 2007 07:03 AM |
| 3-way active. System config options? | jimbo1968 | Everything Else | 0 | 9th June 2005 01:07 PM |
| Audax 652 design options | SndDoofus | Multi-Way | 0 | 22nd February 2005 06:13 AM |
| 3-way design options | goskers | Multi-Way | 7 | 22nd July 2004 06:41 AM |
| Page generated in 0.10878 seconds (68.40% PHP - 31.60% MySQL) with 11 queries |
