Parts Express used to sell a great littel midbase for the money, the Peerless 830341 5.25" midbase. Now I am working on a project to incorporate 4 of them plus tweeter into a pair of 2-way MMTMM boxes. The PE spec sheet on this driver says that “this woofer is great in a .3 cu.ft. vented box tuned to 55Hz, giving an F3 of 60 Hz.” Based on this I assumed that I would use a box ~1.2 cu ft. (since using 4 drivers) with appropriate tuning. When I ran the specs thru winISD pro with a vented box I got a volume of 1.9 for the 4 drivers. Cant figure out where the discrepancy would have come from. Would appreciate any ideas or clarification. Thanks
#2 |
Sadams,
put back the default font of this Forum. BTW, WINisd allows you to insert any reasonable size of box. You are not constrained to using 1.9cubft.
regards Andrew T. |
#3 |
Dont know how the font changed Andrew T., and not sure how to change it now that it is posted
| winisd help please | juxta | Car Audio | 4 | 28th March 2010 04:31 PM |
| Help with Output Cap Discrepancy | Ampersands | Digital Source | 5 | 9th May 2008 01:47 AM |
| Winisd help | Buzzy | Subwoofers | 5 | 28th June 2007 09:01 AM |
| Calling Dr. Fletcher! Dr. Munson! Apparent 20 dB Discrepancy! | kelticwizard | Multi-Way | 10 | 18th November 2004 01:59 PM |
| WinISD. HELP!!!!!!!!!!!!!!!!! | Dannyball | Everything Else | 6 | 30th May 2004 04:24 PM |
| Page generated in 0.07283 seconds (70.16% PHP - 29.84% MySQL) with 10 queries |
