Old 20th February 2011, 07:46 PM   #1
WrineX is offline WrineX  Netherlands
Default Phase response questions
hi, have a question i bought a set of Translator reference , its a dutch brand with only dynaudio drivers. the concept of this speaker is the use of only 6dB octaaf filters and a q factor of 0.5.
first i noticed that i did not have a strong staging of vocals, it feeled like it whas outside the speakers and not in the midlle, thats why i started measuring . when measuring the seperate units up close i noticed that one of the speakers mid dome had a wider responde then the other also the fase behaviour whas completely diferent. so i switched positive and negative on the dome that had a dip between crossover points. well now i measure the speaker at a distance of 50 cm and i thought the phase response of the bass driver whas a bit strange it goes down to minus 180 degree and then come back from the top sene in picture Old. so i changed the positive and negative and now the response look like picture new. is this correct >? or to me it looks straighter but there is this strange peak 250 hertz.
anybody has a clue because all the slopes shoud be 6dB octaaf and therefor pretty damn straight in phase response.
must say its a four way system so for me its dificult to measure.
the dynaudio units i cant see wich pole is wich no indication is this normal ? or do they have there own way of saying wich one is wich.... and also the kabel used has no indication so its really shitty.
this is the system
low 22cm - Dynaudio 21W54
mid: 52mm dome - Dynaudio D52
high: 28mm dome - Dynaudio D28
superhigh: 21mm dome - Dynaudio D21
4-way sealed
crossover: 6 dB/octaaf - phaselineair
crossover freq: 500, 2000 en 8000 Hz
impedantie: 8 Ohm
Q-factor: 0,5
belastbaarheid: 100W continu, 1000W (0,5 sec)
frequentiebereik: 35-40.000 Hz
afmetingen hxbxd: 105x33x35 cm
gewicht: 35 kg
hope somebody know something about phase response and measurements
bythe way this laptop has pretty bad soundcard , for somereason it wont measure above 7K
Phase response inquiry omni Multi-Way 29 2nd December 2008 01:14 PM
Measuring Phase Response of Drivers Iain McNeill Multi-Way 35 15th October 2007 03:13 AM
Phase response and imaging / resolution Branwell Multi-Way 9 25th October 2004 01:00 PM
op-amps - phase response? Dominique Solid State 6 2nd July 2004 04:34 PM
Doubts on Phase Response and Frequency Response dumrum Multi-Way 11 5th April 2004 10:39 AM
Page generated in 0.06884 seconds (69.05% PHP - 30.95% MySQL) with 11 queries
