Old 20th February 2011, 02:06 AM   #1
fxs is offline fxs  Chile
Default Plutos with external power amps?
Hi all. Im thinking about building the Pluto Linkwitz loudspeakers . As i have a nice receiver (a harman kardon with 30w/channel), i was to build only the active crossover, and use the amplifers from the receiver.
Seeing the driver´s specs, their sensitiviyt is about 84dB/watt, and given Linkwitz says the power amps are an integral part of the design(50w for the tweeter, and two bridged 50w for the woofer), not sure if the amps would be underpowered for the speakers, and not listening the full potential of plutos
For those using external amps(especially with less power than specified), how has been your experience? Could be my amps underpowered for driving the Plutos? fwiw, the harman amps are known for being high current, and realistic about the rated power..
Old 20th February 2011, 01:18 PM   #2
I use a vintage 80 WPC Sansui receiver which easily power my Poor Plumber's Plutos at 80 dB/W efficiency and are passively crossed over.
Poor Plumber's Pluto, a novel DIY project
External DC power supply? dannydanger Tubes / Valves 3 30th March 2010 08:51 PM
External power supply audiolace Parts 5 18th January 2007 02:13 PM
external connections for Chip Amps achristilaw Chip Amps 2 8th February 2005 09:27 AM
Power connectors for external PS net-david Chip Amps 1 1st April 2004 04:44 AM
Page generated in 0.07527 seconds (73.51% PHP - 26.49% MySQL) with 10 queries
