Is thare a good way to use two 15" speakers to better cover the Mid Range?
Like using one for the lower end and using the other for the higher end? What would be the best cabinet for these? One small, one larger? One sealed and one vented? Any thoughts? Andy |
#2 |
Seems its like a Quasi three setup like in the Peavey; SP-4 or JBL; JRX125 but I can not find much info on how these are setup. Is it just a crossover? Do thay share the same volume in the box?
Andy |
#3 |
No one with experience using 15" mids?
#4 |
Sure for home use you can use a dedicated 15" like a AE TD15M or JBL2220/2227 and a dedicated LF driver such as a 2235 or a Tempest, but because of the differing sensitivities, active is the most practical way to implement it. I'd keep the mid sealed but the LF can be whatever works best. I've often recommended a similar arrangement with old Tannoys too.
The JBL and Peavey PA units you mention are most likely a 2.5 way with the lower driver being rolled off above maybe 200hz. JBL usually provide a lot of detail in their datasheets and the service manuals (often including the complete schematic). |
#6 |
I agree Pano, and that's exactly what I used for the mids in my PA and my home speakers. But I'm bored with suggesting something that works based upon lots of experience as people usually have their own idea of what they want to use.
#7 | |
I am open to thoughts at this point, ware as all I know so far would be to differant size ported boxs. Andy |
#8 |
What's being used at either side of the frequency range with them?
I assume you'll be crossing them over to a subwoofer, in which case, "midbass" would be more appropriate, as a dedicated midrange might cover 300Hz-5kHz. Not the range for a 15" driver to be considered an effective solution. I'm also pretty sure there's some tapped horn designs for those, so you could get some bass with a few of them, too.
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
#9 | ||
I would like to cover 200 to 2Khz with two 15" Kappa pro's. Eminence says thare are good up to 4kHz but not what kind of enclosure. Thanks Andy |
#10 |
If you have 2" and 1" CDs to run above them, I wouldn't be using the Kappa's out to 2k, more like 800-1k with the 2" on an appropriate flare.
| 15" mid-woofer - 80 Hz to 1 KHz - for a sealed cabinet | audiothings | Multi-Way | 6 | 7th February 2011 10:46 PM |
| line arrays, widerange mid drivers, & crossovers in the "critical range" | darkmoebius | Full Range | 20 | 4th November 2010 05:32 PM |
| 15" + Mid + Horn | Predator864 | Multi-Way | 7 | 4th May 2010 07:28 AM |
| Mid Range driver which one the best? | first_1st | Multi-Way | 18 | 22nd March 2010 03:58 PM |
| Mid range help. | Gioxtream | Multi-Way | 0 | 9th June 2009 02:00 PM |
| Page generated in 0.10279 seconds (79.81% PHP - 20.19% MySQL) with 10 queries |
