I am about to start the long, dirty, messy and possibly dangerous job of building some Horns.
Martins Azura horns look great but i wish to build the horns from laminated stacked rings of plywood. Then finish on a big lathe(another project in itself). I need a 1metre (approx) horn to suit an 8" driver, so a 4" opening looks suitable. For the mid a 600mm horn for a 2" compression driver should do it. Is there a profile drawing anywhere I can use, my skills are more in the practical side of things. Any help is appreciated |
#2 |
You´ll find your answers in the "Jean Michel on LeCleac'h horns" thread. Also, what´s wrong with using Hornresp
Brgds Lars Last edited by revintage; 17th February 2011 at 06:40 PM. |
#4 |
I'll try and learn Hornresp, it will be good to know for my planned built in low bass horn:-)
#5 |
Not a good start, I have winzip and clicked on the download but cant find the file anywhere. After multiple tries i still cant see where the hornresp fie goes!
#6 |
It works on my crappy old work PC. Looks like I have alot of reading to do.
#7 | |
Brgds Lars |
#8 |
i have been playing around with the 8"driver for the 200hZ horn for my proposed horn system.
Can someone let me know if I am heading in the right direction with hornresp. The driver is the Eminence delta pro8B |
#9 |
You are right about Hornresp.
Without knowing the the driver I would guess is early mass rollof.
Brgds Lars |
#10 |
Hi lars
Sorry , not sure what you mean. I plan on using a compression driver above this horn, maybe Tad2001 or B&C DCM50. |
| Le class A and Le monstre parts sell off | danieljw | Swap Meet | 22 | 5th June 2010 09:27 AM |
| Le Class A and Le Monstre based amps for regretful sale | danieljw | Swap Meet | 0 | 9th February 2010 05:08 AM |
| high quality low profile center speaker needed | johnmark | Multi-Way | 0 | 9th September 2009 07:43 PM |
| Le Cleach spreadsheet | jdruley | Multi-Way | 2 | 24th November 2007 04:55 AM |
| Published Le versus measured Le | eddog | Multi-Way | 8 | 11th February 2005 12:30 AM |
| Page generated in 0.08209 seconds (85.05% PHP - 14.95% MySQL) with 11 queries |
