Hello folks. New here on diyaudio. I am combining a 4 ohm tweeter with two 4ohm midbases in a pair of MTM satelites. Already had the midbases or would have bought 8ohm and wired them parallel. Anyway, I want to wire the 4ohm midbases for a final impedance of 4ohms to match the 4ohm tweeter. I have read about series-parallel of 4 identical drivers to give a final impedance matching that of each driver (ex.: 4x4=4). Can I do this with 2 speakers? The other option would be to wire the midbases parallel and place a 2 ohm resistor in line, right? Thanks
#2 |
OK, now I realize my original was a dumb question. You cannot wire 2 drivers series-parallel. So then, my question becomes...with a 4ohm tweeter and 2 4ohm midbase drivers (wired together) in an MTM configuration, am I better off wiring the midbases in parallel and incorporating a 2 ohm resistor, or wiring the midbases in series and putting an l-pad on the tweeter? Thanks
#3 |
frugal-phile(tm)
If you have a voltage source amplifier it will not matter if the woofers are wired in series for 8 ohms nominal and the 4 ohm tweeter. Wiring then in parallel would only be suitable if your amplifier is 2 ohm capablt (not many are). You do not want to add a series R to a woofer.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#4 |
Rebel Samurai!
Ok, good... So then, my question becomes...with a 4ohm tweeter and 2 4ohm midbase drivers (wired together) in an MTM configuration, am I better off wiring the midbases in parallel and incorporating a 2 ohm resistor, This would result in a 2-ohm speaker load plus an equal 2-ohm resistor load. Each load would burn half of the amp output power. So you'd waste a lot of power on that resistor, and you'd need a big macho resistor to avoid smoking it. So don't do this. or wiring the midbases in series This is what you should do. and putting an l-pad on the tweeter? I'm a little confused by this statement... You'd likely need some sort of l-pad either way to match your tweeter's acoustical output to that of your woofers. Are you worried about making the tweeter act like an 8 ohm load? You don't need to worry too much about matching the impedance of your tweeter to that of your woofer, just design the tweeter section of your XO for a 4 ohm load and the woofer section for an 8 ohm load. At least, that's according to my understanding. ... oops, co-temporal w/ Dave... Last edited by AdamThorne; 16th February 2011 at 04:11 PM. |
| Wiring series and then parallel with switch | hemos | Power Supplies | 4 | 17th November 2008 01:34 AM |
| Series-wiring drivers instead of parallel, how does the Xover change? | Glowbug | Multi-Way | 1 | 16th January 2007 04:46 AM |
| Parallel/Series Wiring Question | Javachip | Multi-Way | 3 | 19th September 2006 04:25 AM |
| !2ax7 heater wiring? Series / parallel? | glaznost45 | Tubes / Valves | 1 | 27th February 2006 11:51 AM |
| Multiple Drivers - Series and Parallel Wiring | ralph-bway | Multi-Way | 1 | 17th February 2004 03:38 PM |
| Page generated in 0.09680 seconds (68.50% PHP - 31.50% MySQL) with 10 queries |
