diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Multi-Way (http://www.diyaudio.com/forums/multi-way/)
-   -   to make a center speaker with mid-range drivers of KEF 104ab (http://www.diyaudio.com/forums/multi-way/183230-make-center-speaker-mid-range-drivers-kef-104ab.html)
keffan 15th February 2011 08:09 PM
I have a pair of 104ab which cabinets are bad, foam grills are gone and tweeters have been replaced with tweeters made by Dayton. The mid-ranges and the passive reflectors are still very good. I am considering to make a center channel with the mid-ranges and the Dayton tweeters. I think the vocals should match my 104.2 nicely, which are in very good condition. Need suggestions on design of the cabinet and crossover. Thanks KEFFAN
planet10 15th February 2011 08:44 PM
You'd pnly want to use one of the 104s to make a centre channel. You'd build a box of the same volume (tweeter above or below midbass) and then place the passive wherever convienient, my 1st thot was the back.
Seems a waste thou. B110s would be a better match (wanna trade?)
dave
keffan 15th February 2011 10:10 PM
Thanks for reply. What is the spec for B110?
sreten 15th February 2011 10:10 PM
Hmmm ......
The aB crossovers specifically match selected T27 tweeters .....
You can lose the PR's by using the bass/mids in ~ half volume per driver ....
But I don't like the idea at all .... My advice would be a proper centre design ....
Move on the KEF stuff, fairly sought after on Ebay.
rgds, sreten.
http://sites.google.com/site/undefinition/diy (see FAQs)
http://www.zaphaudio.com
http://www.rjbaudio.com/Audiofiles/FRDtools.html
http://speakerdesignworks.com/
http://www.htguide.com/forum/showthread.php4?t=28655
planet10 15th February 2011 11:29 PM
The B110 i have are the newer SP1057 (called B110B). They would be of a similar time-frame to the B110s in your 104/2.
I have the spec here.
A vertical MTM could be fit in the same space as 1 B200 + tweeter
dave
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
