Old 14th February 2011, 04:46 PM   #1
Default Help needed with tweeter/crossover
Hello.
I'm building a mobile sound system (boom-box) on behalf of my fraternity.
I'm total newbie and the first version was kind of embarrassing.
Now I'm left with:
- two p.audio HP-10W woofers
http://www.ljudia.fi/Archive/Product...-%20Tiedot.pdf
- two two-way first order crossovers (2000hz)
- two complete **** piezos
- a 25w car amp
I think I'm going to do a closed box for the woofers measuring 12,8 liters. Do I get significant advantage if I make it for example 20 liters?
I'm going for mono system so that signal is made mono before the amp, so I can drive another woofer with 25w and a woofer tweeter circuit with another 25w.
So woofers get total of 50w. I'm going to have to make/buy high pass filters for the woofers, ideas welcome.
And then the real problem. I was thinking about Selenium st-200 as the tweeter, but I'm not sure if it can do 2000hz and 16w without blowing.
Should I look for another tweeter, or should I try to get a 4000hz high pass. There was some problems with piezos and crossovers, but I'm not certain which degraded the sound.
http://www.ljudia.fi/Archive/Product...-%20Manual.pdf
Another problem is modest budget of 100eur( 135$ ) Some loosening is possible though.
I'm sorry for my English and I thank in advance for your help.
Old 14th February 2011, 05:52 PM   #2
jerome69's Avatar
Hi
Yes Better Bass. optimum is 34L for one woofer in a closed box.
DT220 : consider use the HP10W 96dB full range -> / 4kHz
105dB SPL / 8ohms -9dB 4kHz for a 6dB crossover R=15ohms C=1uF
Old 14th February 2011, 07:05 PM   #3
Thanks for advice.
Does larger internal volume help bass in 100hz - 300hz region? I have to cut away practically everything below 100 hz as excursion of the HP-10W allows only 107hz as lowest when given 25 watts.
My last box was enormous 130 liter monster and it has severe xmax problems. I thought that smaller box will only cut power from lower frequencies.
Old 15th February 2011, 04:56 AM   #4
jerome69's Avatar
No, it is the contrary
130L is too large for a closed box.
For two woofers in the same box : optimum is 40/50L closed box.
If you already have a 130L box, you can try a Bass Reflex box reduced to 100L@48Hz. The vent is very easy to make : 10cm diameter is 3cm long. 9.5cm is 2cm, 9cm is 1.5cm long. You don't have need a tube, but only a hole in the wood
Yes
Old 15th February 2011, 05:11 AM   #5
AEIOU is offline AEIOU  United States
AEIOU's Avatar
Send a message via AIM to AEIOU Send a message via MSN to AEIOU Send a message via Yahoo to AEIOU
Piezo tweeters don't absolutely need a crossover. Bt they can and will benefit from a properly implemented crossover. Further you cannot just use an off the shelf crossover with a piezo tweeter. The impedance of a piezo tweeter is way, way higher than the usual 4 or 8 ohms. Only the larger professional grade piezo tweeters will go as low as 2,000Hz. Expect an octave higher for budget, cheap, inexpensive piezo tweeters.
Old 15th February 2011, 05:31 AM   #6
picowallspeaker's Avatar
Ultimate advice
It is impossible for a 25 cm paper cone to reach with uniform output ,specially regarding off-axis ,the high frequencies . If those are reproduced by a single unit , using a waveguide of the same diameter (25 cm) would allow a low cut of about 2 KHz ,allowing the use of an high power -little device (compression driver). It can also be found in Pro and Dj equipment .
Old 15th February 2011, 06:57 AM   #7
jerome69's Avatar
Yes but when you have a limited budget, you keep it simple.
Old 15th February 2011, 10:05 AM   #8
The monsterbox has a port and two woofers, the woofers sound good but it's too big to be portable. The piezos actually naturally go somewhere around 1500hz, I had the whole system measured in anechoic chamber, and the piezo area of the frequency response curve looked really zigzag. It might sound like I have so much "professional" help that I don't need you guys, but you are helping a lot.
I have had two signal engineers and one former professional live mixer to help me, but none of them have actually ever built a speaker.
Thanks again.
Old 15th February 2011, 10:42 AM   #9
Piezos are not hi-fi ,not in the band you intend to use them . Could be used above 10-15 KHz ,taking for granted you'll hear them only on axys ,nothing else . Building a wave guide with a dead speaker cone and some plaster can be very easy and inexpensive ,or they are sold for 10-12 $ .
Yes ,for high quality applications compression drivers are expensive ,as they are the only ones that can couple to the air from throat to mouth of a waveguide with velocity .
Then ,measuring a speaker in anechoic chamber can be quite useless ( depending on the applications ) as it doesn't take into account room interactions ....
Old 16th February 2011, 01:58 PM   #10
It's going to be mobile speaker, so I cannot take room interactions into account. It will probably be played outside most of the time.
New tweeter needed. prash Multi-Way 34 25th July 2009 07:09 AM
crossover vs tweeter failure skykomish Multi-Way 5 23rd March 2008 08:15 AM
Rega Tweeter needed magentawhale Multi-Way 1 21st August 2007 08:22 AM
Tweeter crossover question. sugarn Multi-Way 8 27th May 2007 02:29 PM
new tweeter crossover glenwood Multi-Way 0 14th July 2004 09:11 PM
Page generated in 0.12196 seconds (75.80% PHP - 24.20% MySQL) with 10 queries
