I have a pair of Royd Herald stand mount speakers (0.23cu.ft vented box tuned to 43Hz) and I am considering building a pair of floor standing transmission line cabinets(I enjoy woodwork!) to house the same drivers.
Is it correct to assume that I should make the length of line based on the 43Hz frequency employed with the Heralds, or are there other considerations? I'll probably go active with the new speakers, so a passive crossover will be avoided. Peter |
#2 |
frugal-phile(tm)
You need to start by measuring the drivers.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
Thanks for the response, but I don't have the wherewithall or equipment to measure driver parameters, hence my question in my previous post. In different words, "Will a driver that works well in a bass reflex box tuned to 43Hz work as well in a TL enclosure tuned to the same frequency?"
Peter |
#4 |
frugal-phile(tm)
Maybe, maybe not. To design a proper TL you need the driver parameters (like any other box)
The Subwoofer DIY Page - Measurements dave
#5 | |
If you just want to experiment a bit, make a ~52" high rectangular tube with the same external width, depth dims as the existing cabs and place the driver ~18" down from the top. Experiment with the gap height between the open bottom and floor to get the strongest sounding bass response (it's typically quite 'boomy'/'bloated'), then stuff to 'taste' with the highest concentration at the top to quell its strongest pipe modes and somewhat less density down the rest of the pipe to finish smoothing it out. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
Thank you, Planet10 and GM. Experimentation is in order. Will report back later.
#7 |
re:'I don't have the wherewithall or equipment to measure driver parameters' - yes you do, well, almost...To measure drivers: Download ARTA: ARTA ARTA Download, Make this simple jig: ARTA Jig - AudioBlog: A simple loudspeaker measurement jig for ARTA
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
| Small footprint SUB using multiple small drivers | FredrikC | Subwoofers | 5 | 29th August 2010 05:01 AM |
| Small footprint SUB using multiple small drivers | FredrikC | Subwoofers | 0 | 25th August 2010 08:12 PM |
| Small room, Optimo TL or ZRT BR ? | 100db | Multi-Way | 3 | 7th January 2010 05:38 PM |
| tl, tl with other drivers or no tl at all? | beamnet | Multi-Way | 14 | 20th January 2006 03:10 PM |
| How small can you go with a TL? | polsol | Multi-Way | 3 | 12th September 2004 03:24 PM |
| Page generated in 0.09864 seconds (75.37% PHP - 24.63% MySQL) with 11 queries |
