Old 28th July 2003, 11:58 PM   #1
Default Davis Acoustics bass driver
how's this look to ya?
http://www.davis-acoustics.com/gb/produits/hp/series/carbone/25sca10w.htm
Type :
Bass
_
Impedance (Ohm) :
6 ohm
_
Sensitivity (dB) :
92
_
Fs :_
28
_
Re :
5,96
_
Res :
34,32
_
Qms :
2,23
_
Qes :
0,39
_
Qts :
0,33
_
BL :
10,08
_
Xmax :
8
_
Cms :
712
_
Mms :
30,9
_
Vas :
109
_
Aire :
330
_
L :
0,53
-Brad-
Old 7th March 2004, 12:48 PM   #2
dezzz is offline dezzz  Denmark
I have been looking at this driver for some time now, seems its the lightest 10" around? The moving mass is a mere 30,9 grams.
I have been looking for a good 10" to support my Vifa XT18WH driver in the lower regions. And the since the Vifa driver is so light and fast, I would love to have a quick bass as well,.
Has anyone heard this driver? Or does anyone know of even faster quality 10" drivers on the market?
Old 7th March 2004, 01:07 PM   #3
Pjotr's Avatar
Have heard the 25SCA10WW. This is a modified version for use in a TML with a Qt of 0.51 and fs of 25 Hz. It was fitted in a Rogers Monitor TML. I must say it is one of the best bass drivers I’ve heard. Very clean dry bass.
Cheers
Old 7th March 2004, 01:16 PM   #4
I was planning on using it in a closed box... But then I got hooked on the 4th BandPass idea. Heard that it is(in theory atleast) the second fastest of all enclosure types. And then you can make it go lower and at the same time avoid the enourmes inductor that would be needed to cut it of where I would like to do it(and just use a smaller one to get rid of the really high frequencies...).
Old 7th March 2004, 02:31 PM   #5
By the way, is it vital that the two drivers in an Isobaric configuaration is the same? Would be nice if you could use a lower quality(and lower cost) driver as the one mounted the normal way in the sealed chamber, and then use eg. the Davis as the driver mounted opposite?
Old 8th March 2004, 02:05 AM   #6
Ap is offline Ap
Ap's Avatar
MMS on its own doesn't result in 'quick' bass - you have to look at BL as well - think about it light cone & tiny magnet vs heavy cone & huge magnet - you have to take the motor into consideration.
As for 4th order bandpass being the 'quickest' I think you mean the slowest - looka t the high group delay.
My advise is use the driver, its nice, go for either a low Q (< 0.65) alignment or an EBP (oversized, downtuned vented).
Isobarik if size is a concern, but must use the same driver for both.
Old 8th March 2004, 07:29 AM   #7
What I meant was 2. quickest in response. Only outmatched by the closed box(in theory..). I know there may be problems with the phase , but you could always move the box a bit forward to compensate for that.
I assumed that the magnet was of a sufficient size, on a quality driver like this one... Though the picture seems to indicate otherwise...
Has anyone else spotted even lighter 10" drivers? The industry line og Davis speakers, are even lighter, but these seem very low quality, anyone heard these? And what about the prices compared to the Carbon line?
Old 8th March 2004, 10:25 PM   #8
Ap is offline Ap
Ap's Avatar
Not sure what you mean by quickest response- usually that refers to group delay, of which bandpass has the highest.
This is not the same as phase, so moving the box in the room will not change it.
I assumed that the magnet was of a sufficient size, on a quality driver like this one... Though the picture seems to indicate otherwise....
It probably is, you have to look at the spec Bl which is a measurement of motor strength.
I have read using the ratio of mms/BL to arrive at a number for comparisons.
Eg.
mms of 10g/BL of 10 = 1
mms of 20g/Bl of 10 = 2
The lower the number the better.
Bass Reflex design wit the new Hemp Acoustics FR8C driver audio_moksha Multi-Way 4 7th March 2007 08:30 PM
Davis Driver's Any one used ? jleaman Multi-Way 9 8th April 2006 09:32 AM
Davis acoustics opinions/thoughts RyanC Multi-Way 1 24th May 2005 07:53 PM
Looking for unbiased opinions on Davis Acoustics drivers sardonx Multi-Way 0 26th November 2003 06:09 PM
Davis Acoustics for dirt cheap Iron Byron Multi-Way 0 26th August 2002 03:49 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
