Old 12th February 2011, 03:34 PM   #1
percy is offline percy  United States
Default DA-175 v/s SB17
Trying to decide between the Dayton DA-175 and SB Acoustics SB17.
For a 2-way, crossing over around 1700-1800Khz, in a 15-20 Lt ported box.
DA-175 has the cost advantage but no glaring deficiencies compared to the SB17, except for the lowish sensitivity. Any other downsides of the DA-175 that I should be aware of ?
Old 12th February 2011, 04:14 PM   #2
When played loud, SB17 certainly will sound cleaner than DA175.
Old 12th February 2011, 05:53 PM   #3
how loud ? and why ?
Old 12th February 2011, 08:31 PM   #4
how loud? let's say at full xmax of DA175 - 4.2mm
these drivers have similar power handling, DA175 with it's lower sensitivity will never achive SPL and dynamics of a more sensitive SB17, due to power compression.
if you cross at 1700-1800Khz then it will be aluminum vs paper sound. you'd need subjective evaluation. I'd rather listen to resonating paper than aluminum.
Power Handling - SB17 v/s ER18 CA18 percy Multi-Way 6 21st October 2010 09:37 PM
CA18RLY or SB17 ? percy Multi-Way 8 28th September 2010 01:08 PM
Fluke 175 Dmm ? semi932 Equipment & Tools 5 18th May 2010 01:25 AM
UA 175 Urei 175 opacheco Tubes / Valves 1 3rd April 2009 11:32 AM
Anyone with a Carver PM-175 Diagram? Duo Solid State 35 20th March 2005 02:27 PM
Page generated in 0.06803 seconds (69.32% PHP - 30.68% MySQL) with 10 queries
