I do have some 8" woofers and 2.5" fullrangers with me and was wondering whether something like Pluto could be attempted with these. My gut feeling says its possible. Now Pluto uses 5" woofer and is crossed at 1khz to the fullranger . Due to the larger size in this variation the crossover need to be proportionatey lowereed to about 650Hz. This freq is not difficult to handle by my fullranger too. Are there any issues with this line of thought? Also, can the woofer be front firing instead of top for aesthetic reasons? Thanks, Goldy
Audio enthusiast/hobbyist |
#2 |
I think it would work great! I had wondered about tha too. What pipe are you using?
http://gainphile.blogspot.com |
#3 |
RIP
#4 |
Also, I'm afraid that using a 2.5" wide-range driver for the treble would represent another significant divergence from the Pluto principles. It's larger diameter means it will likely start suffering narrowed directivity at a much lower frequency than the Pluto spec.
As Pedroskova just pointed out, omni dispersion as high as possible is a primary goal of Pluto. However, this is not to say that the 2-way you describe won't sound good. It may sound great, but it won't share much in common with Pluto. |
#5 | |
""Much" lower? How "much" lower in frequency will beaming begin with a (nominal) 2.5" driver than with a (nominal) 2" driver? And how "much" will that matter ? ? ? |
#6 |
A typical 8" driver will be roughly -3dB @ 90 degrees at that frequency. Not what I would call omni radiation, but I suppose the distinction might not be that perceptible.
Sorry, I missed the fact that the Pluto tweeter is 2" nominal. I thought it was smaller. So the difference between that and a 2.5" driver may not be that much of a factor. |
#7 |
frugal-phile(tm)
Go for it...
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#8 |
Rebel Samurai!
I've been thinking of something like this for a while... do it and tell me how it works!
#9 | |||
Is there something I am missing? Quote:
If I get encouraging results with the system, I intend to replace it with the Aurasound 2" as in Pluto. Bill, The same -3db @90 (approx) figure applies to the 5" woofer used in Pluto. May be the 5" is special and more omni than a typical woofer, I dont know. You seem to be saying something that is not obvious?
#10 | |
I did an experiment with the 5" pluto clone by lowering the xo from 1000...900...800 etc. The sound should not change as you know it should be omni. But in fact it does change. Unfortunately I only measured 0-180deg. Had I measured 0-360 deg. the resulting graph could be interesting. In your case I would simply build a test box of both, measure 0-360, and decide.
| SL's Pluto | sdclc126 | Multi-Way | 122 | 22nd January 2011 04:08 AM |
| 3-Way Pluto? | sdclc126 | Multi-Way | 17 | 19th November 2007 01:31 PM |
| Pluto hiss? | cuibono | Multi-Way | 15 | 19th November 2006 04:19 AM |
| A Second look at SL's PLUTO | ScottG | Multi-Way | 26 | 25th October 2005 11:48 PM |
| Page generated in 0.15428 seconds (67.40% PHP - 32.60% MySQL) with 10 queries |
