As a life long music-lover and hi-fi user for over 30 years one of the paths to refining the amp/speaker interface - the elimination of the passive network which interposes between the amp and the driver - has been a touchstone for me.I have used an active crossover with absolutely no amp/speaker interposing crossover for the past 8 or so years.
I have in the past used a small speaker(the original AR 18)which used an 8 inch paper cone driver that had absolutely no low-pass crossover element.In fact the 8 inch driver got the entire frequenct spectrum via the rear terminals.The only crossover element was one capacitor for the tweeter at 2KHz. I philosophically like the idea of an arrangement which obliviates the need for an electronic filter by virtue of the natural characteristics of the driver(caused by materials,design or any other means). Are there such beasts? I know this is very open-ended,not the least because I haven't laid-out any particular roll-off frequency I'd like to commence from,what efficiency I'd like to the utilising,minimum or maximum cabinet sizes that I would consider,how much I'm prepared to spend (etc).If I were to be specific I'd be looking for a driver having 500Hz roll-off equiv to 12dB per octave with efficency of 98 dB/W/M. Is there anything out there which has characteristics such as those? |
#2 |
4th order band pass?
#3 |
#4 | |
You shout make a front loaded horn like this. Back Loaded Horns
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 10th February 2011 at 10:19 AM. |
#5 |
I agree with Helmut. A front-loaded horn functions as a natural accoustical lowpass.
Regards, James |
| Inductor hi pass to filter low bass | dcathro | Multi-Way | 12 | 6th September 2010 09:36 PM |
| DIY One fader mixer with Filter Low Pass, Hi Pass, Notch Pass Filter PGM | stevep314 | Analog Line Level | 0 | 10th August 2010 09:15 PM |
| Does Pass D1 roll off treble at low volumes? | kiwi_abroad | Pass Labs | 1 | 17th September 2006 10:53 AM |
| Opamp low-pass roll-off question | ppereira | Solid State | 46 | 6th December 2002 03:44 PM |
| Page generated in 0.10249 seconds (65.65% PHP - 34.35% MySQL) with 10 queries |
