I've been modeling a 2-way design with PCD using the U16RCYP and 27TDFC drivers, in an 11L vented box. The FRD and ZMA files are fully corrected for the box/baffle conditions. When I implement a full BSC design, using a 4 mh inductor before the woofer, there is a 3dB bump centered around 120 Hz. Is this a normal feature of implementing a full BSC design? Attached is an image of the frequency response.
#2 |
It's the second impedance peak of the vented system which alters the working condition of the 4mH self; you may flatten this peak by adding a notch LCR network // to the woofer. edit: 4mH seems relatively huge even for a full BSC. Just my opinion.
crazyhub |
#3 |
I played around with some values for a circuit that would flatten that peak, it seems like I would need some huge caps to do it, so instead a reduced BSC with around 3DB of BSC seems to line up the rest of the FR curve with the 120Hz bump. Looks like a more elegant solution. The room reinforcement should help below that bump correct?
![]() What do you think? |
#4 |
Sure 84dbs efficiency should give a balanced speaker with this woofer in standard rooms and placement.
crazyhub |
| C-C spacing between woofer and tweeter with 500 hz XO | Defo | Multi-Way | 2 | 3rd July 2010 02:31 PM |
| FS large transformer and inductor | woody | Swap Meet | 2 | 10th March 2009 12:20 PM |
| WTB in Oz: modest $ midrangers/ midwoofer (c. 120 - 2400 Hz) | rick57 | Swap Meet | 4 | 9th March 2007 11:50 PM |
| 120 Hz Buzz Unplugged | dr._sleep | Tubes / Valves | 4 | 17th September 2005 02:47 AM |
| woofer up to 3000 Hz ? | promitheus | Multi-Way | 5 | 28th August 2002 05:03 PM |
| Page generated in 0.10993 seconds (47.47% PHP - 52.53% MySQL) with 10 queries |
