Hi, I am making a portable speaker system, and I need to design a crossover. I have a pair of 6" 4Ohm Celestion Mid speakers (came out of a 3 way system) and I am going to buy a pair of Vifa 4Ohm XT25SC90-04's from the internet. I tried calculating a crossover (at 2500Hz) on 2-Way Crossover Designer / Calculator but I have no idea which crossover type to use. Could someone tell me which one to use and also explain what the difference between the crossover types?
#2 |
So I did some research, found one site that said to use second order and another that said I should use a Butterworth design, Is a Second order Butterworth what I should be using for what I want to do?
#3 |
Banned
Since you haven't provided sufficient information about the 6" drivers, I don't think anyone is able to assist you. Do you have the T/S parameters or a link?
Frank |
#4 |
Unfortunately I bought them second hand and am not sure what the specs are apart from them being 4Ohm. As far as I can tell though, They are the mid ranges from a Celestion Ditton 44.
Here's a Pic I found on and old eBay Listing here ![]() ![]() And here's mine ![]() And here's the page for the tweeters I bought. Sorry 'bout this. I'm only just getting into speakers and stuff (well I have been into speakers for a while, got a little collection going, but I'm just starting with the DIY stuff) and this is my first project. |
#5 | |
frugal-phile(tm)
A smallish sealed box would be safe, these are reminisant of early B110, but with a better basket. dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
Would I need to put them in a box to get them measured? Because I have no idea what the dimensions of the box should be. When I first bought them I tested them out by making a box out of a shoe box
![]() Getting them tested would be a professional thing, right? I couldn't just stick a mic in front of them and do it with my PC? |
#7 |
I do not know these drivers. Though, as they were used as midrange drivers, are they suited for a 2 way design?
Will they go low enough? Isn't the Xmax too short? |
#8 | |
frugal-phile(tm)
The Subwoofer DIY Page - Measurements dave
#9 |
I Tested them after I Bought them and they can play down to 20Hz, but they are a little distorted. That's probably because of the amplifier I'm using though, Its a dodgy little DSE 20W surround amp. I'll test it with my Rotel RA-311 when(if) I get it working or I'll try them on dad's Rotel RA-1412 if he lets me
#10 |
Found This eBay listing for a Celestion Ditton 44 3 way crossover. The page says "This is a three way at 500 and 5000Hz third order at 18Db"
Would 5000Hz be okay to use or would I need to re-calculate it once I've put them in new boxes? And are there any differences between a Butterworth and a Bessel Crossover? Thanks for your help |
| Crossover design | hybridfiat | Multi-Way | 27 | 20th July 2008 01:07 PM |
| Crossover Design | argonrepublic | Multi-Way | 2 | 14th July 2005 05:45 AM |
| need help with this crossover design | Xristo | Multi-Way | 2 | 14th January 2005 05:39 AM |
| crossover design | Dave Jones | Multi-Way | 10 | 21st September 2003 07:38 PM |
| Page generated in 0.14887 seconds (65.91% PHP - 34.09% MySQL) with 10 queries |
