Old 7th February 2011, 06:32 AM   #1
Default 15" mid-woofer - 80 Hz to 1 KHz - for a sealed cabinet
Which 15" mid-woofer can very comfortably and accurately do 80 Hz to 1 KHz in a sealed cabinet? This is for a studio monitoring application.
I think we are looking for a Qts of over .4 and, low VAS and an Fs of < 50 Hz? What else should I look for?
Thank you.
Edit: This SB acoustics thing looks quite good. What say?
Old 7th February 2011, 11:50 AM   #2
bwaslo is offline bwaslo  United States
Lambda (Acoustic Elegance) TD15-M
Old 7th February 2011, 03:52 PM   #3
SunRa is offline SunRa  Romania
I wouldn't use that SB acoustics woofer in this specific application for several reasons:
- there's a double dip at 750Hz and 1700Hz followed by a huge peak at 2Khz. I find it hard to equalize it for a cross at 1Khz. In fact I find it impossible to correct.
- the impedance curve shows two ripples at 850Hz and 1700Hz, and they seem corelated with the problems in the response curve. This in fact indicates resonances in the cone, no way you can make these inaudible with that crossover point.
- I just don't like mixed cones (paper and fiberglass)
- It has a low SPL
- I wouldn't cross it above 300Hz in a critical application
Search for the Acoustic Elegance TD15-M. This is the driver to beat. The motor is full of copper, and it has a ruler flat impendance curve. In fact, the woofer is usable up to 2Khz or even more if you don't consider the polar response. Also, the Alu phase plug and the copper in the motor helps for dissipating heat - this improves dynamics. Also it's cheaper than the SB Acoustincs.
There are some projects around with it, search for Gary Dahl, he just finished a nice system.
I am also a big fan of 18 Sound drivers, you may want to take a look there to, there seems to be a lot of technology in them.
Old 7th February 2011, 03:55 PM   #4
badman is offline badman  United States
Custom Title
badman's Avatar
Most good 15"s will do this for you, even the relatively low Qts pro stuff (assuming <40Hz Fs), assuming a touch of room gain.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 7th February 2011, 04:00 PM   #5
tinitus is offline tinitus  Europe
I would take a look at Eminence Kappalite 12"
if you only need 80hz theres no real need for a large 15"
and the same goes for Qts
to do 80hz in closed theres no need for highish Qts
which widens your range of options
Old 7th February 2011, 10:24 PM   #6
ScottG is offline ScottG  United States
15W500 - LF Ferrite Driver
perspective is everything
Old 7th February 2011, 10:46 PM   #7
Custom Title
badman's Avatar
Perhaps I'm overstating- good isn't sufficient, some have breakups right at 1k. Also, JBL 2226h would be well suited, with some care it can perform very well at a 1kHz XO as its breakup is pretty benign and disappears off-axis
8" or 10" sub driver to go with computer speakers, music only, sealed cabinet. doors666 Subwoofers 9 25th November 2010 03:17 PM
80 hz 15' conical midbass horns winslow Swap Meet 1 7th August 2010 12:16 AM
15" woofer in sealed enclosure KCCT82 Multi-Way 23 18th January 2008 03:45 PM
Woofer choice in 2-way sealed cabinet tinos5601 Multi-Way 1 13th March 2007 04:55 AM
Driving a 12" (sealed) subwoof driver up into 300-500 Hz? Dumbass Subwoofers 1 18th November 2005 07:34 PM
Page generated in 0.25073 seconds (34.41% PHP - 65.59% MySQL) with 10 queries
