Is there a simple(ish) way to calculate a theoretical maxSPL when one knows the linear excursion limits and the lowest frequency a driver will be fed without resorting to computer simulations?
#2 | |
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#3 |
Not as helpful as you appear to be thinking.
Basically the question is this: Driver X has a linear excursion of Y mm. If I feed it a band-limited signal say 100Hz to 2kHz how loud could it theoretically go without exceeding its linear excursion? |
#4 |
#5 | |
Piston Excursion calculator b |
#6 |
Thanks bjorno, that indeed does the trick.
It could be that dewardhs link does the same but for some reason the linkwitz lab site never properly loads. It starts, gets stuck and eventually shows an error message. Thanks anyway! |
#7 |
If you're trying to work out how much bass you'll get in a given room, it's quite simple. You need driver sd (surface area), xmax (driven excursion), and room volume. The frequency is irrelevant provided that it is below the lowest room resonance mode. At frequencies below the lowest resonance, the in-room SPL is determined by the room volume difference between "cone in" and cone out".
The formula is: SPL = 197 + 20log(delta vol) - 20log(vol) 1. Calculate the amount of air displaced by the driver at maximum excursion (diaphragm area times xmax). For example, a typical 15 inch driver: 890 mm2 area, 12 mm xmax 89cm2 * 1.2 cm = 1006.8 cc = 1.07 litres. 2. Calculate the room volume. For example, 4m * 3m * 2.4m = 28.8 cubic metres (28800 litres) 3. Do the math: 197 + 20log(1.07) - 20log(28800) = 108.4 dB See this post, and the threads it links to, for background info. modeling room gain Also see Seigfried Linkwitz's notes: http://www.linkwitzlab.com/images/gr...losure-spl.gif The usual disclaimers apply - for example, the SPL is theoretical and depends on a "perfect" room, and ignores resonances and "beaming" effects at higher frequencies. |
#8 |
Cheers mate!
| How to calculate the AWG value ? | binspaul | Parts | 4 | 19th February 2010 11:04 AM |
| help ! how to calculate?????????? | bogdan_borko | Solid State | 3 | 18th January 2006 10:15 PM |
| Calculate BL | Dave Jones | Multi-Way | 19 | 8th May 2004 01:16 AM |
| Calculate BL? | Dave Jones | Multi-Way | 3 | 4th May 2004 08:04 PM |
| Page generated in 0.83031 seconds (10.09% PHP - 89.91% MySQL) with 10 queries |
