Help needed 40Hz to 450Hz
Old 6th February 2011, 10:47 AM   #1
3GGG is offline 3GGG  Australia
Default Help needed 40Hz to 450Hz
I need help for a design for bass enclosure which give 40Hz (or lower) to 450 hz. The higher the effeciency the better. They are to go with a B&C dcm 50 in an Azura horn with fostex T500amk2 on top. Budget is not GOTO but $$$ is ok.
Old 6th February 2011, 01:07 PM   #2
Bill F. is offline Bill F.  United States
Bill F.'s Avatar
Hornresp is a great simulator. Here's a model I did for a ported horn that fits your bandwidth.
Old 6th February 2011, 01:38 PM   #3
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Is this what you are looking for?
That is hard to find look here.http://www.diyaudio.com/forums/multi...d-horns-7.html
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 6th February 2011, 08:55 PM   #4
Thanks Helmuth
Looks promising. Am i correct this is a 15" in a front loaded horn? I see a sketch of a horn a few times in the thread but I am unsure about further details.
If you care to could you post detaails of the driver and enclosure/horn used so i can learn more about the design you have simulated.
Old 6th February 2011, 09:20 PM   #5
Helmuth's Avatar
Originally Posted by 3GGG View Post
Thanks Helmuth
Yes it is a front-loaded bas-mid horn Detail are to find in the last post including the txt file that you can import in hornresp and play with.
The drawing is a suggestion how to build the beyma simulation would fit in a cube of 60cm same as 2feet with a triangle sealed volume. Like the La scala horn.
You should design the horn your self with the data in the simulation. It is a conical horn so it is easy to calculate and make the flare.
Old 6th February 2011, 10:44 PM   #6
ScottG is offline ScottG  United States
2 BD15's in parallel with an appropriate reflex tuning freq..
http://www.bd-design.nl/contents/en-us/d19.html
http://www.phys.tue.nl/EPG/veldhuizen/BD-15.pdf
perspective is everything
Old 6th February 2011, 11:35 PM   #7
Bill F.'s Avatar
Helmuth,
Isn't your sim in 0.5 pi space? Since your drawing does not appear to show a corner horn, better run it again in 1 pi space for a truer picture...
Old 7th February 2011, 12:56 AM   #8
Thanks ScottG, I had forgotten those drivers. Two 15 is still looking like a simple way to do the bottom end and may allow a bit more room for variation with regards to bass mid horn cross over position.
Old 7th February 2011, 12:59 AM   #9
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Calculated to work perfectly with Eminence KappaPro-12 and DeltaPro-12, but not tested
Old 7th February 2011, 01:09 AM   #10
Any further specs to show me tinitus? Looks interesting
Help needed 40Hz to 450HzHide this!Advertise here!
DIY 40HZ TH for DJ use NEO Dan Subwoofers 10 29th January 2010 08:56 AM
40hz seems too much Kelloggrice Subwoofers 7 29th March 2007 12:30 PM
Which BLH for linear response down to 40Hz? Tyimo Full Range 72 22nd December 2005 08:23 PM
I want a subwoofer flat from 10hz-40hz Audiophilenoob Subwoofers 123 13th December 2005 05:10 AM
40hz horn modeled mikee12345 Multi-Way 0 30th September 2003 05:45 AM
Copyright ©1999-2017 diyAudio
