Hi everybody!
I am currently considering a 2.5 way loudspeaker based on some SEAS drivers. So first of all I chose the CA22RNY because of its somewhat higher sensitivity which is something I tend to like in a loudspeaker. (back home I listen to a se 300b amp which is 7.5W). I then started looking for a tweeter and I was thinking of using a regular dome tweeter with a small waveguide in front. However, I came across the Seas 27TBCD tweeter which already has the "lens" and furthermore has a resonance of 900Hz which should allow some control over directionality at the crossover frequency. I would really appreciate some comments on the idea of a speaker based on: Seas 27TBCD Seas CA22RNX Seas CA22RNY The rny being cut at around 400-500Hz to compensate for the baffle step response without losing efficiency. This driver has however a nastier cone break-up resonance at 3kHz so serious attenuation has to be taken into consideration. I am planning on running both bass drivers in independent vented enclosures. So I'm open to any suggestions, comments and criticism. Thanks |
#2 |
The tweeter sensitivity may be a little low after you flatten the response. It looks like about 88 dB above 10k.
#3 |
These are both 3-ways, but use the 22RNX -
His website is incredible, it's worth a long, deep look... 3-Way Classic Poor Man'
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#4 |
Hi.
With those bass drivers vented your talking a pair of very big speakers ..... Take a long hard look at the information here : Zaph|Audio Zaph|Audio Note the treble c/o is applied to both drivers and then one gets the additional baffle step big inductor, a nice and effective arrangement. WG-300 - Monacor special horn front attachment - wave guide - Europe Audio Vifa C17WH- rgds, sreten. undefinition (see FAQs) Zaph|Audio FRD Consortium tools guide RJB Audio Projects Speaker Design Works HTGuide Forum - A Guide to HTguide.com Completed Speaker Designs. Humble Homemade Hifi DIY Loudspeaker Projects Troels Gravesen Quarter Wavelength Loudspeaker Design The Frugal-Horns Site -- High Performance, Low Cost DIY Horn Designs Linkwitz Lab - Loudspeaker Design http://www.musicanddesign.co
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#5 |
He guys ! He wants to use a 7.5W amplifier If you want high sensitivity 96dB, use the same woofers, you must have the same sensitivity in the bass ! 2xCA22RNY and a high efficiency tweeter monacor DT300+Waveguide, TW034 + waveguide SEAS is not a HES (High Efficiency Speaker) manufacturer. Better to see the Troels HES section You can also try a project like this Beyma 15MI100+B&C DE250 and RCF H100 (Better use the 12dB/18dB crossover) 101dB 1W/1m Box 63L@65Hz It is difficult to make a small HES with a lot of bass extension Have Fun. |
| seas prestige L16RNX in doors? | mb2452 | Car Audio | 22 | 12th September 2011 03:16 PM |
| SEAS Prestige 27TFFC | bongolijus | Swap Meet | 4 | 14th June 2010 07:05 AM |
| WTB: SEAS Prestige ER18RNX woofers. | Dkalsi | Swap Meet | 0 | 28th May 2010 02:42 PM |
| P13 or SEAS Prestige MCA15RCY | K-amps | Multi-Way | 28 | 8th January 2010 11:09 AM |
| SB Acoustics vs Seas Prestige | Audiodidakt | Multi-Way | 1 | 1st April 2008 03:14 PM |
| Page generated in 0.31074 seconds (28.74% PHP - 71.26% MySQL) with 10 queries |
