After researching and inspecting many DIY book shelve speakers, and unsuccessfully choosing at least one project, I came to the conclusion that I should design my own project rather then stay overwhelmed. It's already been a huge learning experience and I hope to maintain it, and I hope whatever I produce will influence someone. I've already begin choosing the drivers, this will be a simple two way system, hopefully I'll be able to work in a bass reflex into the front baffle too. I've picked out a couple of speakers so far, I've wanted to build a project with seas drivers, but because of cost restrictions I'll be willing to put up with what I can make due. The two drivers I've selected are:
- SB Acoustics SB17NRXC35-8 - Peerless XT25TG30-04 Considering the SB17, I have conflicted recommendations as to whether the SB17 should be used in a ported or sealed cabinet. Zaph recommends a sealed because of the highish Qts, but the simulations I did in Unibox said ported would be best. I favor the ported over the sealed so i decrease the likely chance of having to use a sub-woof. Could I get some opinions on this? The target size for the enclosure is 20L, the front baffle dimensions will be different depending on sealed vs. closed. I have also started modeling the frequency response in a Excel file, and this is what I came up with so far. ![]() This is with a First order parallel low pass filter (0.42mH) and a second order parallel Highpass filter (C: 6.02uf, L:0.67mH); it's crossed at 2,500Hz. I haven't added any Zoble Networks to manage the impedance, and I'm not sure if I have to. I still need to: 1: Create two separate front baffles and model them in a diffraction simulator 2: Model the frequency response in Speaker workshop 3: Continue reading though Rod Elliot's article for passive crossovers 4: Understand necessary information other people can use to help I've still got a lot of learning to do! Thanks, Kurt Last edited by KnightofAwesome; 5th February 2011 at 10:30 PM. |
#2 |
I prefer ported also. You might want to consider another midwoofer for a vented box. The one you selected will need a very long port to get to the proper tuning. |
#3 |
The breakup on-axis starting at 4k on the manufacturers data-sheet (the blue line) is going to need some serious attention. It will sound really weird if you ignore it or get it wrong.
Trying to get deep bass out of this driver might sound muddy.
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#4 |
Take a good look at : 2-way MT: SB Acoustics SB17NRXC35-8 and Vifa DQ25SC16-04 (Poor Man's High End) - Techtalk Speaker Building, Audio, Video, and Electronics Customer Discussion Forum From Parts-Express.com rgds, sreten.
There is nothing so practical as a really good theory - Ludwig Boltzmann When your only tool is a hammer, every problem looks like a nail - Abraham Maslow |
#5 |
Location: Mar del Plata, a BIG seasonal getaway city, can see the Ocean from our residence.
I ran the numbers on my end....I got 88.88 for efficiency bandwidth product, putting it square into the ported camp. Ported box volume at 29.84 liters , Fb at 35.486 Hz. Rather deep bass for such a small enclosure! Yes indeed the tweeter response needs to be smoothed out..she's juking all over the map!
If you can push up that dip at 3700 Hz by 2 Db you should be OK. __________________________________________________ _Rick.......... Last edited by Richard Ellis; 6th February 2011 at 02:55 AM. Reason: Additional thoughts |
#6 |
First off, thanks for all the helpful posts
This is all I can do tonight, this crossover is not final. I've got an impedance trace but i don't think it's a good one. I've attempted to get another trace, but the auto SPL tracer is being difficult, I'll try it again tomorrow. Since these will mostly be used as computer speakers, It's still possible that having a bass reflex will make being about 1m too bassy. but for the time being, I've got them highs tamed! (I don't know the importance of the Total Frequency Graph, but none the less, it's there) ![]() Kurt |
#7 | |
With that said, have you looked at peak excursion? Unibox shows: VB Excursion SB.gif At 20 watts, peak excursion is reached. |
#8 |
The L-pad on the woofer is simply totally wrong. Take a very good look at the design I posted. rgds, sreten.
#9 | ||
As for the design you posted, I thank you. I've copied the woofer schematic into speakerwork shop, but since it crosses over at 1.9 Khz I'd have to rework everything. Zaph recommends the tweeter be crossed at 2Khz with a 4th order or a 2.5Khz 2ed order and no less. |
#10 |
Speakerholic
![]() Never seen one on a serious speaker. |
| TDA2500 - does anybody have a PCB designed? | Disney_SK | Class D | 7 | 18th March 2008 01:28 PM |
| Designed by Rabbitz | lazyfly | Full Range | 16 | 27th November 2006 10:02 PM |
| Need Newly Designed Enclosure | ttvonau | Car Audio | 0 | 25th September 2006 05:20 PM |
| Can you hear the crossover point of a speaker with a well-designed crossover? | 454Casull | Multi-Way | 11 | 2nd April 2004 05:48 AM |
| Any new computer designed tubes? | Circlotron | Tubes / Valves | 2 | 5th June 2002 01:30 PM |
| Page generated in 0.33838 seconds (30.75% PHP - 69.25% MySQL) with 11 queries |
