Old 2nd February 2011, 08:23 PM   #1
Default Fast blow AGC fuses vs polyswitches
Which is better for speaker driver protection?
Old 8th February 2011, 05:58 AM   #2
wolf_teeth's Avatar
If you don't want any incresaed series resistance, use the fast-blow. The Polyswitches, IME, have about 1 ohm added DCR to your signal chain.
Recommendation: Whichever you choose, place a 15 ohm resistor in parallel with it so you know the driver protected is okay. It will just be a lot lower in output level.
Later,
Wolf
Photobucket picture pages: http://photobucket.com/Wolf-Speakers_and_more
Writeups/thoughts/blogs: http://techtalk.parts-express.com/blog.php?u=4102
Old 8th February 2011, 07:13 AM   #3
Mooly's Avatar
As above... the fuse is best.
It all really depends what you are protecting against.
DC offset ? A small offset can cause a significant current which can overheat and burn out a driver. It's unlikely as most DC faults cause a full rail voltage to appear but it can happen. In either event a fuse may not provide enough protection depending on its value and the speaker itself. So DC offset protection is recommended.
Overload due to excessive volume ? A fuse is fine, particularly if the amp never clips.
A simulation free zone. Design it, build it, test it.
Old 8th February 2011, 08:39 AM   #4
just another
wintermute's Avatar
Only the very low current polyswitches have a DCR of 1ohm or more. See attached.
Also if you are running 4 ohm speakers you need a bigger current polyswitch dropping the DCR even more.
For an 8 ohm speaker protected to around 22 watts an RXE110 will do the trick and the DCR at 20c is between 0.15ohms and 0.25 ohms a far cry from 1 Ohm. (from Jaycars datasheet http://www.jaycar.com.au/images_uploaded/polyswit.pdf )
RXE110 pdf, RXE110 description, RXE110 datasheets, RXE110 view ::: ALLDATASHEET :::
the figure of .38 ohms 1 hour post trip is interesting and I would hope that it does return to the nominal resistance range after a while.
I've used polyswitches in the past and the did exactly what they were supposed too. Protected my drivers against over zealous party goers who pushed the amp into clipping. Before the polyswitches I had many a blown tweeter and occasionally a blown midrange!
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Onkyo Sub will not power up (fuses blow) zsmith28 Subwoofers 6 16th May 2010 08:00 PM
NAD fuses, slow blow or fast blow? AllCaster Solid State 3 25th October 2009 06:11 PM
Adcom GFA-535 Blow fuses after connected to MG-Is vacs2000 Solid State 0 26th February 2009 07:35 PM
Completed LM 4780-but fuses blow? Dominick22 Chip Amps 27 6th January 2006 04:08 AM
fast / slow blow fuses millwood Everything Else 3 5th January 2004 05:49 PM
Page generated in 0.13394 seconds (48.34% PHP - 51.66% MySQL) with 11 queries
